Who Know To Make Spark Plug Spark More Stronger
gunkhean
Hi there, anybody know how to make spark plug spark more stronger? I dun think just changed the ignition coil/irridium plug will help & i already tested it. My question is, is that possible to make more supply from startor coil/ magneto stator supply for ignition coil, then ignition coil will produce more spark with racing ignition coil & irridium plug. Any idea?
Hi,
Changing your Spark plug, ignition coil doesn't really improve the performance but the reliability of the spark you will get. It is the same as with cars. Iridium/platinum spark plugs will not increase or do anything but just prevent fouling and misfiring if your A/F mixture is bad, or your engine is not tuned. For well maintained engine, changing to iridium/platinum will have no observed effect.
I use iridium spark plugs for my Turbocharged Car which really helps maintain the spark despite the compression. Copper is still the best conductor for spark plugs. Changing your plug with four electrode will help you increase your compression ratio a bit. :)
Just keep on replacing your plugs every three months or at least 6 months using NGK or OEM plugs will help you more than buying an iridium plug using it for a year. :)
mac kevin
one time here in my place in a certain motorshop, ive seen one honda wave 125 (with no cover=naked) w/ its driver coming out from the said shop with an obvious huge size of ignition coil attached on it, ive made some inquires to the shop personnel just to verify and make it sure what kind of coil was that, and guess what, hmmmmm... its no less than ignition coil of a multicab, i have no idea what is the effect to his bike using such big coil... (its size is like wrist of a man)
so bro... if u need boost of power going to sparkplug, can i recommend u to try this one in your t135? hehehe, im just curios..:oops::eek:
Mac Kevin, yes i've seen a lot these in our Place and i also own a multicab before and had also modified it. The ignition coil is much bigger than a motorcycle, it produces reliable spark. But spark is still spark, it will not increase the Horsepower but will definitely increase the response. If it has a real power increase, you should see this in UBK championship or in local circuit racing but i haven't seen one. :)
Paladin
This is true and it worked for me. I use Bosch ignition coil for a 3k engine. Better response and more reliable. You can use any type of spark plugs on this.
It's even easy to install. My high tension wire are even for a 3k engine. No hustle at all.
