Why My Bike Feel "heavy" When Riding?
gunkhean
my bike feel heavy when riding, the bike can go very smooth, but heavy. t'm using
1) 62mm ceramic block kit
2) minor porting head with stock valve
3) mikuni VM30 carby with 190mj, 37.5pj
4) yoshi pipe.
5) no air filter.
gunkhean
I use 15-37 it suppose to have better acceleration & feel more "lighter" when ride. I dun know why. Please help.
gunkhean
Sir traxxas, wheel bearing is stock. & my tyre i use 90/80 in front, 100/70 at rear, rim size is 1.85 at front, 2.15 at rear 17 inch.
gunkhean
ok. i will retune the carb this week, & may i know is that possible the timing of cam not install perfect enough when installing & become like that? & what is the perfect mj & pj for my carb?
turbulence
im using keihin 28mm carb bro. i tried 62mm and my mj is 115 n pj 42. 55km/liter. im not sure if thats the same with mikuni.
suplado010
i think sprocket only...because your rear tire is very big and you are using hi speed sprocket so in result very poor acceleration but very good top speed..
gunkhean
i dun think my top speed is good because i just can reach 155km/h. all my friend with my spec with have at least 180 km/h & above.
gunkhean
I retune my carb & have my sprocket changed, i changed to 14-35, the result is quit the same. Just more top speed, feel "heavy" is still the same
gunkhean
i think maybe is my auto clutch problem causing i feel my bike so "heavy" when riding, can auto clutch will cause this problem? what is the simptom of auto cluch or clutch housing is wearing out?
neil888
try to change the sprocket into 14/39...im using 60mm faito block, faito turbo cams, faito valve springs and clutch springs, 2.15 x 17 front reams 80/80 tires and 2.50 x17 rear 90/80 tires, stock CDI..... it can reach 140KPH.....
neil888
try to change the sprocket into 14/39...im using 60mm faito block, faito turbo cams, faito valve springs and clutch springs, 2.15 x 17 front reams 80/80 tires and 2.50 x17 rear 90/80 tires, stock CDI..... it can reach 140KPH.....;);););)
neil888
neil888
try to change the sprocket into 14/39...im using 60mm faito block, faito turbo cams, faito valve springs and clutch springs, 2.15 x 17 front rims 80/80 tires and 2.50 x17 rear 90/80 tires, stock CDI..... it can reach 140KPH.....;);););)
