zcbitik
Google itcan you show me a pic to what does it look like bro
.. you can search for GPS Holux M-241 as one of the sample here
Isnt this dangerous? hard to check those readings on a motorcycle specially when riding a motorcycle in a highspeed... IMHO brothers... I know everybody here is an expert rider but I think its really risky crazy doing it..tie it in the side mirror bro
with electrical tape.
wrap your gps gadget with plastic
then tie the body in the side mirror![]()
...Hi all
for the benefit of worldwide owners of T135
Lets post here the speedometer accuracy of our T135 with FRONT STOCK TIRE.
If you have a GPS, please have it compared with the bike speedometer panel.
Lets compile the different speedo accuracy of T135 in different countries.
When testing:
-Please pay particular attention to the 100kph on bike speedometer vs the GPS reading
-Front tire must be SAME SIZE as original tire
Yamaha X1R Thailand (thanks to jchris1124)
Actual speedo x1r *** GPS garmin m0bilext In kph
10 *** 8.5
20 *** 17
40 *** 35
60 *** 53
100 *** 90
120 *** 108
135 *** 120
Sir Mafiaflix, had you ever test your top speed bike sir? and compare it to gps ? ThxI have compared my speedometer's top speed with android HTC Evo 3D device which navitel program installed on that,
the result shown 10 km/h heavier in android GPS than real speed on my meter.
110 km/h in speedometer = 100 km/h in navitel program.
before you use your gps. make sure to connect to satellite. im using nokia e72. go to application then choose gps data.you will see navigation, position and trip distance. use trip distance but be sure to connect to satellite. by checking to to option and click satellite status. when the bars turn to sky blue. it connect to the satellite and you can use your gps. click option then press start. the fastest you drive the max speed will record.can you show me a pic to what does it look like bro
SAME WITH ME...130KPH ON XRM TAILING ON ME BUT ON MY GAUGE 1O5KPH ONLY....USING 80/80 FRONT 100% SETTING ON MY KOSO DIGITAL SPEEDO...Hi guys, do you have account on the accuracy of KOSO digital speedometer at 100% tire differantial? It looks like mine is not accurate as it seems.
bro can u post thier guide on how to calibrate koso digital speedo...i can't do per gear. Using stock and UMA digital speedometer.
Bike: T135 5 speed, front 80/80 90/80 rear FDR Sports XR Evo
Stock GPS
120kph - 112kph
UMA GPS
125kph 118KPH
I was on break in period using my stock Speedo. Switch @1k to UMA.
Setting is 120% in UMA and used their guide on how to calibrate it by measuring the wheel diameter.
Bro. I am using UMA digital speedometer. ill try to post it later once I have freetime.bro can u post thier guide on how to calibrate koso digital speedo...
pix may help..tnx...![]()
Hi all
When testing:
10 *** 8.5
20 *** 17
40 *** 35
60 *** 53
100 *** 90
120 *** 108
135 *** 120
