[WTA] FZ150I CAM VS UMA RACING CAM
ImNotStig
Salam...
Nk tnya.. Moto gear 4 mati xde tork
Gear 3 130
Gear 4 120
*meter motor
Bdan tegak...
Lc v1 es
Spec moto
Block 57
Cam fz
Sv cms
Hyperclutch
21T
Carb standart MJ 110 PJ standart carb
Tayar blkang 110
Ekzoz cj ipoh M1 silent type
Sproket 14 34
Berat 55kg
Heran.. Top mati xmau nek2..dia mati kat citu...
Tolong otai skalian.. Kat mana kurang nye haa nk bg dpt 160 atau out meter dgn spec sedia ada
man_sate
As salam smua , nak tnye saiz spoket yg sesuai utk spec fz ni bpe yer ?? Moto saya 135 5 speed .
Tggu sape2 yang penah pakai spec fz dekat 5 speed bagi cadangan...bole cube turun 1-2 mata spoket belakang...
Salam...
Gear 3 130
Gear 4 120
*meter motor
Bdan tegak...
Lc v1 es
Spec moto
Block 57
Cam fz
Sv cms
Hyperclutch
21T
Tayar blkang 110
Sproket 14 34
Berat 55kg
V1 Extreme Spirit (Clutch) kan?
Main spoket depan 15...belakang pakai 38/37...
Pakai MJ standet 105...110 minyak lebih time full throttle...
Set balik carburetor...
Ak pakai Lc V1 ES gak...time standart penah kene bole pegi 120 je walopon full throttle...
Sbb ak adjust TPS dengan set carburetor sendiri....ade mende tsilap...siap hanta hong leong sg buloh suh cek balik...pon xbole setel gak....120 gak walopon da bpuluh-puluh km...
Last ak tuka carburetor lain..carburetor standard gak...setel masalah...outmeter tp dalam 20km - 30 km...:dance:
ImNotStig
Ya, kita pkai Extreme Spirit,
Sy ada buat eksperiment,
sy masuk Carb uma28
14 34 top 140
14 30 top 120
pgi nie sy try 15 34 top 120... :(:(:(
Next eksperiment nk try..
14 33
14 35
cdagan please...
sy ase gear ratio sy berat sgt, munkin satu factor dia xmau g.
sy rase laa.. adeh...
ingat nk pkaai LOW CAM GTC racing (Popeye).
LOW CAM kena buat pocket valve kat piston.
HIGH CAM CMS T2 Plug n play saja...
Pendapat korang semua cam ner..
LOW CAM ker HIGH CAM.
man_sate
sy masuk Carb uma28
14 34 top 140
14 30 top 120
14 33
14 35
cdagan please...
Kalau lc v1 es main spoket depan 15...
15-34 xlarat moto dengan spec fz.. Paling koman kene pakai 62mm.. Pakai 15-38 je...
Spec fz main low cam atau cam standard je... Pakai high cam nanti top mmg ade.. pickup mati.. Bukan pickup mati je... Nak dapat top bpuluh2 kilo sebab piston kecik.. Kalau kene kat bukit pon akan drop banyak...
Cdi tuka?
Ni experience saya time pakai spec fz 5 taun lpas...
ImNotStig
Se
Cdi tuka?
Setakat ini sy pkai cam FZ lagi. ingat this week nk masuk cam CMS T2. tgk la mcm ne performance dia.
klu tgk sprokect nie.. ratio dia xjauh..
15 38 2.53
14 34 2.42
tggu bulan len la nk tukar.. haha
Bab Pickup, sy boleh advance sy punya ignation timing sampi 44 BDTC
CDI dh pkai BRT smartClick
set BDTC 35, tp on dual band, jd 37. dlu set 37 which is 39, ase cam okay ckit. xtau lah..
RPM 12.5
ssh nk dpt perbezaan dia. nk feel betul2..
Klu pickup xleu belah gak. sy nk advance satu mata timing gear. satu mata jatuh 9 degree.
agak2... klu sy ADVANCE satu mata, berlaga tak valve dengan piston?
man_sate
Se
15 38 2.53
14 34 2.42
RPM 12.5
1 mata 10°..kalau advance 1 mata tu org panggil marking lari.. Marking lari bole sbb kn valve blaga... Pembakaran xbtol... Dan effect kat setting.. Maximum pon 6° tapi kene pakai adjustable timing gear nk dpt kan 1°-6°..
Walopon advance tok pickup tp akan effect dekat top speed.. Rasanya tau pe side effect advance kalau da tau advance & retard..
Ignition timing saya selalu set 29° rpm 14k tapi tiada perubahan ketara dari segi pickup atau top speed kalau set ke nombor lain..
Ratio mmg hampir sama.. Tapi top speed lebih cepat mati main spoket depan 14..14 ni tok 5s.... 4s main spoket depan 15 adjust belakang je.. Sementara pakai je dulu...
Bole la cube.. Sy cume cakap bdasarkn pengalaman..
ImNotStig
Okay.. Baik.. Kita readjust balik BDTC 29°..
Kena cancel timing gear advance adjust...
Sy tau klu over advance.. Enjin knocking nnti...pastu meletup la enjin... Uhuk3...
Berbalik pasal cam... Ramai org kata cam cms nie okay.. So, boleh masuk la kowt....
Eh jap... Xyah buat pocket valve ker... Lift dia dh tggi... 5.8mm tu...
man_sate
Memang bole masok dan okay.. Tapi cam ni berbeza2 profile die sbb tu kene ikot spec block dan head.. Kalau cam tu xkene dgn spec... Moto lemau dan xpergi...
Cam cms lift 5.8mm tu nama lain die high cam.. High cam sesuai untuk block besar 60mm ke atas... Sekarang majoriti 62mm/63mm... 60mm da jarang org pakai...
Macam saya ckp sbelom ni.. Pakai high cam dekat block fz saiz 57mm menyebabkan pickup takde... Tok adekan pickup kene besarkn piston...
Cube cari low cam.. Low cam sesuai tok 60mm ke bawah... Ataupon cam potong...
*kite tgu otai lain bagi cadangan
ImNotStig
So far sy cuba td... Pickup semput2... Top bergegar ckit mintak gear.. Tp xpulas abis lagi... Mnkin BDTC sy ubah 37.. Sy nk try 29 pula nnti.. Tgk result mcm ner...
Bunyi tick..tick..tick pun xkuat.. Sy puas hati cara pemsanagan dia...
Tggu besok baru boleh test moto tu.. Musim hujan..
Jika ada modal len nnti.. Baru kita up block... Pkai mana ada dlu sampi hancur... Huhu...
man_sate
:thumbsup::thumbsup::thumbsup:
ImNotStig
First try masa xubah BDTC.. Top 120 ja.. Hare!!
Tukar balik BDTC 29..set carb balik.. Baru spt 145 dok tegak...
Tu pun.. Carb x set betul2... Nnti nk kena tgk plug.. Huhu..
Mkn masa nk dpt tune cantik neh... Hmmm
man_sate
Banyak beza top speed.. Pickup semput2 lagi?
Memang makan masa nak fine tune kalau cuba2...bile da tau senang dan sekejap je...
