Joel, if I have a company trip to Bangalore, I'll definitely pay you a visit to look at your engine modding skills *cheers*
Inspire, mine can't even start to pull at 120kph on 4th gear (m'sia meter). But right now, first to third gear acceleration is freaking great.
1st : 55kph (prev. 40kph)
2nd: 85kph (prev. 70kph)
3rd: 120kph (prev. 110kph)
4th: 135kph (prev. 150kph+)
4th gear somehow missed the powerband when I upshift from 3rd gear. I am using sprocket 15-42, which suppose to have more accel and lower top speed, but the first 3 gears are pulling a lot further now.
Our stock carb takes in too much air and not enough fuel. I've tried to polish the intake port of the carb slightly, but problem still exist. Lifted the jet needle up by 1 'tick' still does not solved my problem.
Right now, my Mikuni 28mm is using #230 mainjet. It gives me freaking good power, but the mid range pull is still a bit sluggish. low end is good if I am using idle jets, anything after 80kph on 4th gear starts to get sluggish..
inspire, where do you get this lo-cam? How is the lobe separation angle and duration compared to stock cam?
