depedal
this is the updated link for the machine rules
http://www.yamaha-motor.com.ph/racing/y ... 135ss.html
ganun talaga sir, we're promoting stock racing kasi eh..but rest is assured, walang makakalusot na mandaraya kahit gabihin tayo sa scrutineering ok lang,,,basta fair and square...sa suitt naman siguradong may kakasya para sa lahat...ganun din sa boots and other gears...raider125jeigh said:I was able to read the whole rules and so sad that others can use or I mean replace the 4th gear ? ouch baklas makina un..
Any way depedal and jamescore Sali tayo..
And need ko lang tangalin ay ung clutch spring ko.. others ok na..
Hindi din pala pwede Slick tire – tsk tsk tsk.. battlax pwede IRC and FDR tires hindi pwede kasi slick un.. hay wala na me pera pambili ng tires ..
PAPA MARK may kakasya ba saken na race suit im around 5’8-5’9
Wala kasi me suit..
Thanks..
Sana hindi na kasali ung replace ng 4th gear hahaha- kasi stock – cant afford kami sa opening ng ENGINE hahahasOnicmArk said:ganun talaga sir, we're promoting stock racing kasi eh..but rest is assured, walang makakalusot na mandaraya kahit gabihin tayo sa scrutineering ok lang,,,basta fair and square...sa suitt naman siguradong may kakasya para sa lahat...ganun din sa boots and other gears...raider125jeigh said:I was able to read the whole rules and so sad that others can use or I mean replace the 4th gear ? ouch baklas makina un..
Wala kasi me suit..
Thanks..
register na mga fafa!!!
Jeff can you organized our TEAM T135the_one said:s tingin ko ndi nyo nman mgagamit ang 4th gear d2! s liit ng track malamang 2nd gear ang babad d2.. magconcentrate nlng kyo s advance tune up ng motor & ofcourse lots of CONFIDENCE pra manalo ang team YamahaT135.COM!!!
@depedal
paps kung serious k s SUPER STOCK cge puntahan ntin si bullets..
@all
maganda siguro kung meron tayong iisang mech ung talagang may experience s circuit racing! n pwede nting dalin s event mismo pra tulungan tyo just incase may aberyang mangyari s motor nyo! suggestion lng papa pra s TEAM din nman..
master question, ano yung modified 4th gear?traxxas-modifier said:i think pwede malaman if modified 4th gear ang sniper without opening the engine.
using tachometer with gear ratio value like veypor...
but again yamaha mechanics are willing to open up the engine :-D
for me . ill join just for fun and experience
naka carb na pala si depedal, kaya palang iniiwan ako nung nag kasabay kamiraider125jeigh said:Jeff can you organized our TEAM T135the_one said:s tingin ko ndi nyo nman mgagamit ang 4th gear d2! s liit ng track malamang 2nd gear ang babad d2.. magconcentrate nlng kyo s advance tune up ng motor & ofcourse lots of CONFIDENCE pra manalo ang team YamahaT135.COM!!!
@depedal
@all
I still have small bruises on my thigh but I can still play for the sake of our Team.
We need to practice once or twice a week before the event.
Tatangalin ko lang ung clutch spring ko.. budget lang problema..need pa ng battlax na gulong..
We need support.. thanks guys..
Ang alam kong maglalaro is si Jamescore at depedal.. pero si depedal magbabalik stock kasi nakacarb sya..
UP ko lang papa MARK…
hahahatofujelly said:sir jobs sasali ka? wow sana umabot ka sa finals para may admin goes to manila heheh
goodluck sa mga sasali ^^
raider125jeigh said:Sana hindi na kasali ung replace ng 4th gear hahaha- kasi stock – cant afford kami sa opening ng ENGINE hahahasOnicmArk said:ganun talaga sir, we're promoting stock racing kasi eh..but rest is assured, walang makakalusot na mandaraya kahit gabihin tayo sa scrutineering ok lang,,,basta fair and square...sa suitt naman siguradong may kakasya para sa lahat...ganun din sa boots and other gears...raider125jeigh said:I was able to read the whole rules and so sad that others can use or I mean replace the 4th gear ? ouch baklas makina un..
Wala kasi me suit..
Thanks..
Tama ba eto ung rule nayan
Change of final gear ratio is allowed. Front & rear sprockets. Change and modification of the primary gear and transmission is not allowed.
Don’t worry comment lang to paap mark ..nakikirace alng kami kayo masusunod hahaha
Thanks papa Mark – may mapapahiram na gears
Paregister na kami kausapin ko lang sila
Ilan naba kasali sa stock 135cc
Muah..muah..muah,,,
May information naba kung anung itsura ng track?
Cones ba ung mga corners,with rubber tires ba sya?
JamesCore said:sir mark medyo di ko na gets yung sa ruling ng bodyworks.. correct ko lang po kung pwede ba yung naka underneathe? altered na yung rear cowlings ko..
defenitely d2 kyo paps 135CC SUPERSTOCK (135SS) CATEGORY wlng expert jan..raider125jeigh said:JamesCore said:sir mark medyo di ko na gets yung sa ruling ng bodyworks.. correct ko lang po kung pwede ba yung naka underneathe? altered na yung rear cowlings ko..
Pwede ata naka UNDERNEAT
Papa mark
Just to clarify..
EXPERT CLASS ba ang 135cc .. sa picture kasi ng sniper may nalagay expert... pero sa ruling beginners and novice
KAMING MGA nagbabalak sumali sa T135 e BEGINNERS na hindi pa nakasali sa mga CIRCUIT racing..
Kung baga e 100% newbies kami like nung nagpalaro kayo sa boomland..
Sasali nga sana me dun namatay lang kasi step mom ko..
Sana hindi experts ang kalaban..
ILAN ang minimum na racer for the 135cc special category??
sir, medyo nagka mis Que lang dun sa picture regarding 135ss, di po expert yun pang beginner novice po lahat ng categories...the_one said:defenitely d2 kyo paps 135CC SUPERSTOCK (135SS) CATEGORY wlng expert jan..raider125jeigh said:JamesCore said:sir mark medyo di ko na gets yung sa ruling ng bodyworks.. correct ko lang po kung pwede ba yung naka underneathe? altered na yung rear cowlings ko..
Papa mark
Just to clarify..
