Yamaha Lc Bearing Code
phl6684
Bearings
Crankshaft Left = 6305/C3
Crankshaft Right = 6305/C3
Camshaft = 6001-Z
Camshaft = 6906 /C3
Transmission =6002
Transmission =6202
Transmission =6004
Transmission =6204
Front Wheel Left =6300-Z/MT
Front Wheel Right =6300-Z/MT
Rear Wheel Left =6301-RS1/MT
Rear Wheel Right=6301-Z/MT
Rear Sprocket Drum =6004-Z/C3
Water Pump bearing =6000
Clutch Plate pressure bearing = 6901
Oil Seal
kick starter oil seal = 16 x 26 x 5
engine sprocket oil seal = 20 x 35 x 5
waterpump oil seal = 10 x 31 x 13.5
rear mags sprocket oil seal = 26 x 42 x 8
front mags oil seal = 20 x 35 x 7
credit to mr traxxas....
kamen rider x
Bearings
Camshaft = 6001-Z
Camshaft = 6906 /C3
Transmission =6002
Transmission =6202
Transmission =6004
Transmission =6204
Oil Seal
Thank for the info MOD PHL.. ;););)
phl6684
bro seli
jenama terpulang bro..nsk ada skf,fag,koyo, mcm2 ada...kod sama ja..
bro adi
selasa dia bg quotation harga skf n nsk...hehehehehe
Wpt - Kcy
bro seli
bro adi
hang ambik quotation SKF biasa atau high speed bearing atau SKF Enduro....abg tak pernah pakai lagi SKF nie. sbb masa mula-mula racing dulu depa ajar FAG atau IBC ja hahahahahahahahhaha:p
WhiteT135lc
nie link dia
http://www.mudah.my/Set+Bearing+SKF+C3+untuk+Yamaha+135LC-12712023.htm
Kami ade pakej menarik, pd harga yg sgt menarik. Fullset bearing C3 dlm enjin anda.
Complete bearing dlm enjin,Crankshaft, gearbox, clutch, crankcase,dll = 6 Bijik
HARGE Cuma RM180 sahaje untuk full set bearing enjin!(6 BIJI) Dijual secara pakej.
Juga terdapat pakej ekonomi untuk crankshaft & gearbox sahaja. Sila call utk maklumat lanjut
ha.... cam ner... dengar mmg best.... cer kita sembangkan
Wpt - Kcy
nie link dia
http://www.mudah.my/Set Bearing SKF C3 untuk Yamaha 135LC-12712023.htm
yang dia bg biasa punya SKF steel bearing nie kla nak upgrade cari yang jenis SKF ENDURO C3 , kla yang racing SKF CERAMIC C4 bagi highrpm enjin a.k.a mereka yang tamakkan kuasa, nie contohnya
SKF Enduro - The Racing Spirit
SKF ENDURO known as bearing for racing, is used for high performance motorcycle, ensuring long service life in extreme conditions.
There are two types based on application:
1. Engine - Crankshaft
2. Wheel
1. Crankshaft bearing features:
- Super hardened high quality bearing steel
- Special heat treated for retainer
- High-grade steel ball
- High-precision internal radial clearance
- Super finished raceway surface
2. Wheel bearing features:
- High quality bearing steel
- Capping solution (metal and rubber) for maximum protection
- Special grease
Special Quality Through Innovation
SKF Enduro special features give the following benefits:
- Improve protection against contaminations as, for example,
water, dust and rust
- Increase bearing service life
- Lower maintenance cost
- Increased operating temperature
tapi selama saya pakai bearing racing pernah FAG dgn IBC...but my vote goes to IBC saya pakai dekat crankshaft saja, saya pakai dr tahun 2009, cuma pada moto baru nie saya tak pasang lagi, buat rujukan:
Buat tatapan Kawan2 semua tentang IBC Bearing::::
http://www.ibc-waelzlager.com/
http://www.spekuma.se/info/Super%20Precision%20Bearings.pdf
