Yamaha T135 w/ liquid cooled and oil cooled(converted only)
the doctor
for as long as d head gets d lubricant it needs there wil b no prob. .hpe u could provide a pic on the ais part
docgabby
how may kilometers have you already traveled with this setup? do you periodically inspect your cams for "overheating" or is it getting lubricated well???
what i meant by cams overheating is that if not enough oil goes adequately to the cams for lubrication they become dark discolored as if they were burned. due to metal to metal friction from the cam lobes and the rocker arm.
the doctor
my wories on ths mod is that the head gets a lot of oil in such a way that it would damage other part,.in ths case the valve seal. .
karl0321
how did you say that the head gets a lot of oil? - i think Same amount of oil coming through the head because i just got the oil coming from the screw(oil going to the cam) and connect to the oil cooler.
Head gets lot of oil - even thou lot of oil coming to the head will not damage any part of it because the oil will be going down to the low part of the engine.
karl0321
Yes sir your right, i think there is really a discoloration on the cam if there is not enough of oil coming to the cam.
docgabby
its not about the head getting lots of oil, its about the oil going to the vital parts of the head. the valve springs don't need oil, its more of the cam lobe to roller rocker arm contact, that's why oil to the head goes there first thru the middle of the cams out thru holes that lubricates the cam lobe then drains back to the center case. with this setup since oil is split with less oil gong the "normal way", some oil goes thru the plumbing then pours from above. you may have an oil cooler but is lubrication still the same? lesser? or more?
docgabby
This is oil cooler that i have installed.....at the back of oil cooler....I put a 135 lc radiator fan....and I tap the oil cooler line from the oil filter cap....
this is a better design for me. how did you modify the cover for the oil that goes out of the cover must not be the same path the oil returns...:rolleyes::cool:;) .Photo0153.jpg
man_sate
In the oil filter cap....the oil will have in and out....it will go out from the middle and in/return to upper.....if u have installed racing boy filter (transparent one)....u will see the oil will pressured up from middle....:):):)....
docgabby
sir can you show us an up close picture of your modified oil filter cover, inside and out...
Samboy Del Rosario
+1 to docgabby.. can you show us more picture of your DIY oil cooler sir.
in and out of the oil is direct to oil filter cover?
man_sate
thank you sniperCJ.
I will upload the picture soon......when I change my oil filter.......ok bro.....;););)......
my latest adjust for oil cooler : I change the hose from 8mm to 6mm....:)
