I'm just the rider so i dont normally get involved with that level of tech detail. I guess what i was hoping for is a pointer to what is available that will suit this bike, i dont even know that currently.CryptonX said:about cams if you know how a cam works then u will understand what result you will get from each camsaft that is in market
welcome here sameer!Sameer said:Hey guys i'm from India and i race in the nationals here, i just booked this bike and i'm already thinking about stuff i can do to it to improve performance. I saw another neat thread on tips and tricks for the T135, do you guys have any suggestions for this bike? any common tips that should work on the R15? Any after market ECUs available? bigger bore kit?
Please move this to another thread if it shouldnt be here. Thanks in advance
Sameer
Thanks for the fuel injection system picture, really appreciate your effort. Apart from the component that you mentioned, did you notice any sensor? For example mass airflow sensor on the throttle body or along the intake manifold? or is there is any other sensor on the exhaust pipe?CryptonX said:at last i have the pics
i post them here cause i dont know where to post or i should open a new topic
I agree, i have tested the bike and felt the same thing. Just when you start enjoying the power up top it hits that damn limiter. Do let me know if you find a way to remove it.CryptonX said:well couldnt take a pic of the ecu cause its removed from the bike and the only thing that kills that bike its his rev limiter
because the true power of the bike comes at high rpm its rev limiter kills its power so we doing some research about removing the limiter. thats the only info for now for more you have to w8 till i get my items and test them![]()
you talk about the know power commander brand?Paradox said:why need to reboring if only u got 'power commander'. nowadays, electronics rules!! :lol:
R15/fz150i is using an open loop fuel injection system..which pretty sucks...FalangRider said:As far as i se this is an old type of injection Yamaha is using, i was thinking yamaha was using the newest tecnology on their bikes.
Because to reduce the cost of bike. otherwise it would be 20% cost of bike.FalangRider said:As far as i se this is an old type of injection Yamaha is using, i was thinking yamaha was using the newest tecnology on their bikes.
