200cc - Which Would You Choose
rowan
I kinda confuse my TK big valves head from Haen come with another set of retainer. I wonder can the 22/18 TK valve head use the UMA titanium retainer instead of using the bigger retainer that come with the TK big valves head by Haen??? Pic coming soon..
haen use 5mm valvestem thats why he use diff retainer
docgabby
i noticed some of the nut doc were not fully tightened . is shim applied below the valve cover?
pls educate us .thanks
still need to do adjustment on valve clearance. no shim applied, the underside of the valve cap has a nipple.
-=Sniper21=-
wow i lily lily like this thread but for the TS' for me papz! i choose 3.5mm jack crank with 62mm block and plus more and more mod,good luck to your project,feel the power of mamaw mods..hihi
back to you guy's...:D
HKholic
I thought the same at first glance. Looks similar to a "shim under bucket" set-up minus the tappet screws.
rowan
care to show the nipple hehehe what i mean the valve cap..
coz, r150 valve cap is flat..or that one is specially made when you ordered from thai?
rhoitol
i dont think so bro. bigger bore need bigger valves.
personally im using vixion kit and 22/19
our admin (traxxas)uses vixion kit and 22/18 valves
we can easily out run those who were using stock valves its not plug and play thing.
example"this racing boy products before they claimed it 28hp im sure they have tested it and have it installed properly
i wont be same 28hp if someone bought it and never put it right .
60mm borekit with 22/19 valves is way more powerful than our vixion kit w/22 19 valves
we personally do it and tested it
rowan Vixion block of this set up of yours and Admin was Squish/shave?..by how many mm?..thanks in advance Idol..
blackknightrealms
guys do you have a pics of those modding that you do on the parts and during assembly?it may help a lot. a please tr to mention brand name if you can and cost and if you some additional modification on this particular parts.what the purpose of doing that and you know what i mean. We are like student in the class with different instructor on the front.just like one of the forum-er mention before...please "educate"us!:D thanks for all your patient and dedication on all this information. please continue telling us more. include your pros and cons of parts that you selected during your modding.:dance:
haen
I got the feeling that UMA head is very big... Not suitable for normal machine that below 190cc... Need to be over 190cc to put that head on. I have been testing normal big bore like 60mm and 62mm using big head like 22/20 head but when i fight with machine with the same bore but using stock head. The Big head still loose to the small head bike... The power come not fast enough... Even big head is powerful but it take longer time before the power come.. Unless if the machine is jack rod than only i can can feel the not sinking power come pouring down to me.
really well spoken sir TryX !!... this problem is the common symptom of big valve heads, power at 5000 rpm above ! so except you ride on long tracks you'll almost be beaten for sure on short tracks by stock head with proper porting :D
Usually this problem was tried to be solved by stroking it up and / or increase the compression ratio. But both method got its advantage and disadvantage.
For example : stroke up = lower max safe rpm, knick knack on installation and development etc,
higher compression ratio = more heat, more stress hahahahha
the problem with 4 valve cyl heads is their positioning of intake and ex valves.. on overlap event (cam event) on low rpm they tend to scavenge the fresh gas excessively due the close distance compared to cross positioned 2 valves head.
Also the nature of the 4 valve cyl head is tumbling flow, not much swirl like 2 valve.. but u know what ? that also got solved !
Enter the PolyQuad architecture of 4 valve.. by varying valve size (staggering), porting and cross placing the valves and varying shroud area size to promote SWIRL and TUMBLE we got VVT effect by a cheap method. Seriously, this was hidden secret until now.. on Mitsubishi car engine this trick produces strong low rpm power yet retains advantages of more power at high rpm !
Will update again on the result.
check this out...
Uploaded with ImageShack.us
EDIT :
apparently on previous post docgabby posted a photo which implement almost the same concept port bias, valve staggering, valve shroud vari-size will see how this concept on the LC135 head :D
Thanks for pointing that out doc !
that UMA head if it implements this concept it would be possible achieving 28 hp but not on under 11:1 comp ratio, look at the intake port, wonder do they sell the intake manifold too..
TryX
But sir Haen as the solutions you mentions isit possible to be implement in to the LC135 head???
Btw that uma head got like double circle intake port... And so big not suitable for smaller carbs... If put on everyday ride it gonna drain the petrol like water... Probably need bigger tank for that.. So the UMA head is good news for circuit rider but bad news for everyday rider...
I drive Mitsubishi car before. They lack of low RPM power is true but it still give insane power in high RPM!! coz of the MIVEC cam profiles..
haen
But sir Haen as the solutions you mentions isit possible to be implement in to the LC135 head??? Can show any picture of how it was done? (Maybe other vehicle is also ok.. Not necessary have to be LC135 head) I just want to have that idea how it look like.
very possible... although we have to create our valves first...
docgabby
Can try up to 0.7mm that what my friend done on his daily bike. But if u got the ball than can go up to 1mm :p
why do you need to do this?? isnt it much better to modify combustion chamber to unshroud valves and promote better flow? you want to reduce squish band to increase compression but yet the area of the stock valves still need unshrouding to promote better flow. why not just use hicompression piston instead.
