I got the feeling that UMA head is very big... Not suitable for normal machine that below 190cc... Need to be over 190cc to put that head on. I have been testing normal big bore like 60mm and 62mm using big head like 22/20 head but when i fight with machine with the same bore but using stock head. The Big head still loose to the small head bike... The power come not fast enough... Even big head is powerful but it take longer time before the power come.. Unless if the machine is jack rod than only i can can feel the not sinking power come pouring down to me.
really well spoken sir TryX !!... this problem is the common symptom of big valve heads, power at 5000 rpm above ! so except you ride on long tracks you'll almost be beaten for sure on short tracks by stock head with proper porting
Usually this problem was tried to be solved by stroking it up and / or increase the compression ratio. But both method got its advantage and disadvantage.
For example : stroke up = lower max safe rpm, knick knack on installation and development etc,
higher compression ratio = more heat, more stress hahahahha
the problem with 4 valve cyl heads is their positioning of intake and ex valves.. on overlap event (cam event) on low rpm they tend to scavenge the fresh gas excessively due the close distance compared to cross positioned 2 valves head.
Also the nature of the 4 valve cyl head is tumbling flow, not much swirl like 2 valve.. but u know what ? that also got solved !
Enter the PolyQuad architecture of 4 valve.. by varying valve size (staggering), porting and cross placing the valves and varying shroud area size to promote SWIRL and TUMBLE we got VVT effect by a cheap method. Seriously, this was hidden secret until now.. on Mitsubishi car engine this trick produces strong low rpm power yet retains advantages of more power at high rpm !
Will update again on the result.
check this out...
Uploaded with
ImageShack.us
EDIT :
apparently on previous post docgabby posted a photo which implement almost the same concept port bias, valve staggering, valve shroud vari-size will see how this concept on the LC135 head
Thanks for pointing that out doc !
that UMA head if it implements this concept it would be possible achieving 28 hp but not on under 11:1 comp ratio, look at the intake port, wonder do they sell the intake manifold too..
