actually its for my daily driver 210cc.hehehehe..i was trying to play around with gear ratios trying to get a wide ratio for my daily driver. the drag bike ratio is different coz its close ratio 4 speed (close ratio is defined as high speed first gear, low speed 2nd, 3rd, fourth). mine is more for highway cruising speeds dats why i chose a wide ratio (wide ratio is defined as low speed first gear, high speed second, third and fourth). my wide ratio combination is:Doc and i are discussing privately about using some gear parts for his monster 200cc sniper
2011 sniper part number
50C–E7151–00 GEAR, 5TH PINION (27T) [#2 in 2011]
"Looks like" can be replaced to the old versions
1S7–E7141–00 GEAR, 4TH PINION (22T) [#3 in old]
which will results to having a 4th gear ratio of 23/27 = 0.851
based from the drawing, it looks like its possible.
yup it does...but with the digital world there are less papers to put weights on........doc at least it still has a purpose![]()
doc
sniper mx has Fifth gear 26/27 =0.963
and not 27/26 = 1.038
if the stock 23 / 26 aftermarket=0.884 in the photo were fit
i guess theres a high chance that stock 23/ 27 mx =0.851 also will fit
the 27 will give you much wider ratio on your mamaws 4th gear.
if it wont work at least it still has a purpose
hopefully???????![]()
doc gabbyView attachment 9485
i was looking for a 26T pinion (as seen in this picture) to match the stock 23T main gear for a wider fourth gear. sir traxxas did mention about the fifth gear from either a sniper mx (27T) or the vixion (23T) since they look very similar based on the catalog. the only problem if it will match the stock 23T main??? i could go trial and error for both the fifth gear vixion or mx but if the teeth dont match when they turn then it would be two expensive paper weights.
