interceptor
reserve one for me sir...
ok sirinterceptor said:reserve one for me sir...
actually its ok sir, but if u want more, things that u said are recommendedunlimited express said:Is it ok not to modify anything else like port n polish if we were going to use the monster block? will replace only the block itself and nothing more.
thanks for your comments...
@pitsbike, pls. PM me the transaction detailsPitsBike said:actually its ok sir, but if u want more, things that u said are recommendedunlimited express said:Is it ok not to modify anything else like port n polish if we were going to use the monster block? will replace only the block itself and nothing more.
BAd potots....bad....pototoy316 said:@pitsbike, pls. PM me the transaction detailsPitsBike said:actually its ok sir, but if u want more, things that u said are recommendedunlimited express said:Is it ok not to modify anything else like port n polish if we were going to use the monster block? will replace only the block itself and nothing more.
thanks
marcusfilter said:BAd potots....bad....pototoy316 said:@pitsbike, pls. PM me the transaction detailsPitsBike said:actually its ok sir, but if u want more, things that u said are recommendedunlimited express said:Is it ok not to modify anything else like port n polish if we were going to use the monster block? will replace only the block itself and nothing more.
thanks
go for it pres...marcusfilter said:uhmmm..I will think about it...
I dont think that this will work with elegance, Cause our Nuovo is 2 valves, correct me if I am wrong...jim said:does anyone knows if this bore up kit applicable to nouvo elegance 135LC? I really wanted an upgrade for my engine I hope this is the solution.
any inputs will be appreciated.. thanks!
thanks for the reply sir! I think there will be no problem with the cylinderhead of the elegance what's important is the cylinderblock it should match the holes of the stock block of the elegance if there will be a match then it would be a goodnews!marcusfilter said:I dont think that this will work with elegance, Cause our Nuovo is 2 valves, correct me if I am wrong...jim said:does anyone knows if this bore up kit applicable to nouvo elegance 135LC? I really wanted an upgrade for my engine I hope this is the solution.
That's the problem with Elegance now where to find a big bore for it.
ride safe
To better answer this one sir you may contact Mon, Chief mechanic of REVZONE, He can help you with regards to this one.jim said:thanks for the reply sir! I think there will be no problem with the cylinderhead of the elegance what's important is the cylinderblock it should match the holes of the stock block of the elegance if there will be a match then it would be a goodnews!marcusfilter said:I dont think that this will work with elegance, Cause our Nuovo is 2 valves, correct me if I am wrong...jim said:does anyone knows if this bore up kit applicable to nouvo elegance 135LC? I really wanted an upgrade for my engine I hope this is the solution.
ride safe![]()
