61mm cmr steel bore Kit vs. 57mm vixion kit
vhadz
well, base to experience and base to they advise and understanding they methods of bore as my master boss thopiang said, main thing is patience in using steel bores, its all upon they driver,, me and boss thops have used almost they same modifacation but still hes so mamaw inside i cant catch up with him, if he goes 120kph mine is 100kph only wehehe ,, u can upgrade anything even ur using steel bores, but when ur driving try to listen to ur engine especially to d knocking and cams tikitic, when ur in top of ur speed put limit into it, at top maybe 3-5mins then break free from sthrottle 6-10mins at topspeed using steel bores, check my thread ull get they answer, u need to let ur steel bore breath , ayt!! :thumbsup:
bcoz if u wont and when ur riding with boss thops sermonan kau nyan, wahaha peace boss thops.:D
adam_john99
paps are you telling that we need to remove the part #7 to be able to use the Estarter even with a high cam?
Nop.the slot only available at standard or uma racing cam only.the high cam or low cam depends on manufacturer doesnt have this slot.this slot only help the e stater to rotates the crancshaft without using highload/high amp on the battery
muvee abdullah
ohw so it depends on the cam right paps? thanks for the info
adam_john99
roger that, fyi, if you looking for topspeed/hispeed/highway/long track, i would suggest you to go for low cam, but if you looking for pickup/short track/drag, better use hi cam, both cams depends on the other setting like bore diameter, head intake & exhaust port (port & polish), exhaust setting and carb you are using.
cheers...
muvee abdullah
cheers...
cheers for the cam :thumbsup:
Johnny Tran
Ok bottom line out of curiosity, if you had your pick at these:
Vixion 57mm, faito 60mm, cmr 61mm, uma 62mm...
Which one would you choose for daily riding (durability) but also for exceptional racing power (good balance between both)?
mj viloria
ill go for the uma 62mm first its ceramic coated so your talking about one of the most durable block ever built for our t135..and second with a 62mm engine displacement comes with a monstrous power :)
vhadz
61 cmr bro, been using this for long race, drag race, stock pipe, no probs, it upon ur settings bro, all of this items had there power within but its up to the mechanics if he had techniques on how to loss out its power and durability.. its about the combination of knowledge & guts on how & what do u want from ur bike..:D
but even your bike is so powerfull but the driver dont have the heart its useless, just put it back to stock.. :dance:
boogaks12
Hey vhads do u have any experience or idea about vixion kit ...we installed it and do the hard break in..but the sad part my engine goes in noisy sound like taktaktak..after hitting 130 kph ...my beloved vixion is 2 weeks old now...so we open again the block to see what is the realy problm..and we found out that 1 side of block have a scrathes on the bottom about 3inches also the base of the piston..any idea boss?tnx 4 d reply..
boogaks12
I thought vixion kit oem is very durable wetherhard or soft break in..and all the sellers says plug and ride..cur.set.stage 2 lhk,valbe spring rcing,rcdi...
