61mm cmr steel bore Kit vs. 57mm vixion kit
vhadz
Hey vhads do u have any experience or idea about vixion kit ...we installed it and do the hard break in..but the sad part my engine goes in noisy sound like taktaktak..after hitting 130 kph ...my beloved vixion is 2 weeks old now...so we open again the block to see what is the realy problm..and we found out that 1 side of block have a scrathes on the bottom about 3inches also the base of the piston..any idea boss?tnx 4 d reply..
haven't try this vixxion in my bike, but one of our members is using this and we tested it to the fullest, i have nothing to say about its durability, thumps up, but in urs case, whos ur mechanic or are you the one who install it, maybe u had forgot something on setting it, but now i cant tell what went wrong, wejeje pls declare the lud of ur cylender head,, ride safe.. ;)
boogaks12
Im the one who installed it and i followed all the basic assembly and setting of my bike...ya your right maybe something is missing...
1. New and good oil
2.forgot to install base gasket( for highcomp)
3.stock carb not rejjeted
4.rider
5.?....
Back to stock as of now...still seaching for good people like u who do share the secrets of our modification..
Actually the noise is allmost desame as the stock config..maybe the chain ..cause i remove the base gasket...
Im just wondering why my vixion kit dont last...what do you think?
rowan
1. New and good oil
4.rider
5.?....
you still have a lot of things to do and to know keep on searching the site its all here only thing u make halukay
ill show you one nd keep on reading and analyzed more dont just follw all what they are saying check this link.
http://www.yamahat135.com/threads/some-proven-tips-and-tricks-for-t135.547/
.. admin will explain to you what is really meant by plug and play.
number 3. stock carb not rejetted???? wow its ur first mistake remember ur adding displacement and even dont have base gasket..still u dont rejet?
keep on reading my friend.. hindi ka nag iisa marami dyan katulad mo. kulang lng basa basa muna then aplly logically
boogaks12
Still using my deffective vixion...most durable and reliable kit that i used ...hehehe..
No white smoke with good power and slight knocking...aw..:)
