arjaydotcom
cge paps paPM nmn..tnx..if ever san b pwedeng ipagawa pag my parts na?chiglai said:medyo madugo sya bro, pero yaka, if your really interested i can pm you the price of the parts and kung ano ang kelangan e modify, thanks
AS IN salpak na lang yan or my tabasin pa?chiglai said:everything under my AC to HC convertion can be ordered thru me, it cost 6k lahat ng parts, completo pati crankcase cover,
here is a list of the parts,
93315-108Y5 - BEARING
90201-12876 - WASHER, PLATE
93102-12862 - OIL SEAL
90508-14800 - SPRING, TORSION
2S4-E6340-00 - PUSH LEVER ASSY
2S4-E6382-00 - AXLE, PUSH LEVER
99080-09600 - CIRCLIP
2S6-E5421-00 - COVER, CRANKCASE 2
1S7-E5461-00 - GASKET, CRANKCASE COVER 2
2S6-F6335-00 - CABLE, CLUTCH
2S6-E6351-00 - PLATE, PRESSURE 1
2S6-E6181-00 - SPACER 1
2S4-E6111-00 - GEAR, PRIMARY DRIVE
2S6-E7411-00 - AXLE, MAIN
ung balancer na ginawa ko that was only for race use or should i say daily ride, you can weld the stock centrifugal without any problems,
may masama kang balak pre.. :twisted:Rjet100 said:hmmmm type ko mag kanu kaya aabutin sir chinglai kung lahat lahat pati labor?
renier ayun oh set na..chiglai said:6.5k po lahat sama na dun ang bayad sa machine shop...
uu sabihin ko sa kanya to.. wait natin reply ni sir Chinglai..Rjet100 said:sir chinglai me contact number b kau? para ma contact ko na kau @dwyale ivan sabihin mo ke dinther eto na lang gawin sa kanya
