kikaipitoy
@BP
poppa sa akin din nag BF what to do?? Ok sana takbo YYpang kaso pag bitaw sa throttle inuubo..TIA
sa akin endi naman ganun.. palinis mo carb and pa tono mo na dinboldstardex said:mga sir,yung sa akin may backfire pag matagal ako mag chage gear tapos galit nagalit na yung makina,pag change gear ko may isang "BOOG" na tunog..pano po mawala yun sir? dbs po gamit ko
how to do carb tuning?im using yypang bigelbow,my backfire gone when i tuned my carb.its tedious job of removing the spark plug and puttingit back again until i got the correct burn,after that no backfire anymore.
febe gienel celebria @ its almost here na sa forum natin,just get the post of sir traxass pic of a good,or perfect type of burn picture and compare that with your spark plug,start from 1 1/8 turns up till 2 1/4 turn on your a/f till you get the right burn,i suggest 1/8 of a turn then run bike(mine every 7km) then remove spark plug.if the burn is not good clean it put it back,then ride your bike again.gang makuha mo o ma losethread! joke!ahihihihi!,if you have a good mechanic at your place better let him do it.how to do carb tuning?
thats mr. veteran.. hehe.. try try try until ma loose thread hahafebe gienel celebria @ its almost here na sa forum natin,just get the post of sir traxass pic of a good,or perfect type of burn picture and compare that with your spark plug,start from 1 1/8 turns up till 2 1/4 turn on your a/f till you get the right burn,i suggest 1/8 of a turn then run bike(mine every 7km) then remove spark plug.if the burn is not good clean it put it back,then ride your bike again.gang makuha mo o ma losethread! joke!ahihihihi!,if you have a good mechanic at your place better let him do it.
normal ba yun papi?xcs user.. positive bakfire at full throttle
sabi nla normal dw kasi mababa octane level ng xcs.. try mo blazenormal ba yun papi?
cge papi.. salamat sa infosabi nla normal dw kasi mababa octane level ng xcs.. try mo blaze
