BACKFIRE
nave
try mo linisin ung air induction system m pre, bka my singaw n ung reed valve dhil sa dmi ng carbon deposit.. un ung sa ibabaw ng head.. o kya 2lad ng sbi nla takpan m nlng un..
chat_master08
sir.. kung d pa din nawawala ung backfire ng pipe mo. try mo check ung pipe mismo. kc ung sakin sa ribits (sorry d ko alam correct spelling) nilalagyan ko ng silicone gasket at pati ung sa may pinagkabitan na may spring. kung stock naman ang motor.. wala masyado prob. effective yan sir..and also check mo din pipe kc minsan mahuna nabibili natin na pipe baka may mga cracks or something.. and also check the gasket sa pipe. baka andun din. good luck
boldstardex
mga sir,yung sa akin may backfire pag matagal ako mag chage gear tapos galit nagalit na yung makina,pag change gear ko may isang "BOOG" na tunog..pano po mawala yun sir? dbs po gamit ko
elyouch
sa akin endi naman ganun.. palinis mo carb and pa tono mo na din
odie
im using yypang bigelbow,my backfire gone when i tuned my carb.its tedious job of removing the spark plug and puttingit back again until i got the correct burn,after that no backfire anymore.
odie
how to do carb tuning?
febe gienel celebria @ its almost here na sa forum natin,just get the post of sir traxass pic of a good,or perfect type of burn picture and compare that with your spark plug,start from 1 1/8 turns up till 2 1/4 turn on your a/f till you get the right burn,i suggest 1/8 of a turn then run bike(mine every 7km) then remove spark plug.if the burn is not good clean it put it back,then ride your bike again.gang makuha mo o ma losethread! joke!ahihihihi!,if you have a good mechanic at your place better let him do it.
thats mr. veteran.. hehe.. try try try until ma loose thread haha
sniper_boss
hindi umabra rejetting s akin..hnd kaya nawawalan ng supply ng gasolina..107.5 kaya binalik k s dati..open pipe pla,,
sniper_boss
i read some article about AIS that causing backfire i tried it to close by a slipper rubber on the AIS and the backfire gone and the tune of my bike is better not unlike when the AIS is open the tune is like the tune going high and then go back to low tune for a second then high tune again...
karlo
up for this.. after my first very long ride (manila to nueva ecija) ayun nagback fire na yung motor ko.. eto lang ginawa ko, nagswitch ako from unleaded to petron XCS.. ayun! tumipid sa gasolina tapos biglang backfire na.. advice mga master
