Best Sprocket Combi
rhovic
,how about for sniper classic with 90/80r and 80/80f with no cut-off cdi(orange yamaha cdi from thailand) and 50kgs rider and the rest are all stock,what is the best sprocket combi?
Thanks in advance..:)
attiado
Sprocket combi
Front teeth | Rear teeth= Gear Ratio
16 34 = 2.125
15 32 = 2.13
16 35 = 2.19
15 33 = 2.20
16 36 = 2.25
15 34 = 2.26
14 32 = 2.28
16 37 = 2.31
15 35 = 2.33
14 33 = 2.35
16 38 = 2.38
15 36 = 2.4
14 34 = 2.42
16 39 = 2.44
15 37 = 2.47
16 40 = 2.5
14 35 = 2.5
15 38 = 2.53
16 41 = 2.56
14 36 = 2.57
15 39 = 2.6 Stock gear ratio
16 42 = 2.63
14 37 = 2.64
15 40 = 2.67
16 43 = 2.69
14 38 = 2.71
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 42 = 2.8
16 45 = 2.81
14 40 = 2.86
15 43 = 2.87
16 46 = 2.88
14 41 = 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
14 42 = 3
15 46 = 3.07
14 43 = 3.07
14 44 = 3.14
14 45 = 3.21
14 46 = 3.29
so if you want more top speed than stock settings
use 14t front and 36t rear
or 16t front and 41t rear
if you want more acceleration
use 13t front and 34t rear
or 16t front and 42t rear
BIGGER TIRES (100/80 and up): use color red
SMALLER TIRES (80/80 and below): use color blue
References: traxxas-modifier, Nov 26, 2007 Report
Sih Jae Jin
If you want higher top speed and not sacrifice acceleration with your tire combination please use 15-40, or you can use stock sprocket combination 15-39 with change on 4th gearbox ratio so your engine don't go overdrive when shifting your gear from 3rd to 4th.
sir, ano po ang dapat na sprocket pra sa bagong sniper mx 135 ko? stock pa po lahat! pls advice me...
Sih Jae Jin
Sprocket combi
16 34 = 2.125
15 32 = 2.13
16 35 = 2.19
15 33 = 2.20
16 36 = 2.25
15 34 = 2.26
14 32 = 2.28
16 37 = 2.31
15 35 = 2.33
14 33 = 2.35
16 38 = 2.38
15 36 = 2.4
14 34 = 2.42
16 39 = 2.44
15 37 = 2.47
16 40 = 2.5
14 35 = 2.5
15 38 = 2.53
16 41 = 2.56
14 36 = 2.57
16 42 = 2.63
14 37 = 2.64
15 40 = 2.67
16 43 = 2.69
14 38 = 2.71
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 42 = 2.8
16 45 = 2.81
14 40 = 2.86
15 43 = 2.87
16 46 = 2.88
14 41 = 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
14 42 = 3
15 46 = 3.07
14 43 = 3.07
14 44 = 3.14
14 45 = 3.21
14 46 = 3.29
sir, what is the best combnation sprocket for my new sniper mx 135??? all stock! :)
VChard
If stock engine stay to stock sprocket combi 15/39 AFAIK
im wid my stock engine sniper, sprocket (15 x 42)..tire size (80 x 70) frnt, (90x80) rear..stock pipe.. 3rd gear at 95-100kph..and 4th gear about 120kph max..if i change my sprocket to (15 x 41) is it possible that my topspeed wud increase? btw, im 85kg rider.:confused: :help: thanks :D
any idea sir @humanbasic ? and sir @sagad , and sir @JhayBoo . thanks :)
Snipeepee
Good morning guys! just wanna ask what best combi do you think applies to a 62mm bore,rcdi,90/80 80/80 tire ratio/80kg rider?im trying to achieve my top end.. TIA! More Power.. :D btw sniper classic user here..
Thotz Herrera
stock engine; front tire 70/90; rear 100/70; stock sprocket 14/38; my weight 60kg
when it comes to 5th gear, i noticed it doesn't have power anymore. they told me to change sprockets, but i dont know what combination will i do.. can you help me?
what sprocket combi is best for my mc? thanks!
