try this 15-42,how about for sniper classic with 90/80r and 80/80f with no cut-off cdi(orange yamaha cdi from thailand) and 50kgs rider and the rest are all stock,what is the best sprocket combi?
Thanks in advance..![]()
thanks for the suggestion bro.,is good for accel. and top speed?try this 15-42
ride safe
no prob bro btw did you get your top speed?thanks for the suggestion bro.,is good for accel. and top speed?
as of now bro i don't know its becoz the gear unit assy is not working anymoreno prob bro btw did you get your top speed?
, anyway it's not my bike it's my brother's bike hehesir, ano po ang dapat na sprocket pra sa bagong sniper mx 135 ko? stock pa po lahat! pls advice me...If you want higher top speed and not sacrifice acceleration with your tire combination please use 15-40, or you can use stock sprocket combination 15-39 with change on 4th gearbox ratio so your engine don't go overdrive when shifting your gear from 3rd to 4th.
sir, what is the best combnation sprocket for my new sniper mx 135??? all stock!Sprocket combi
Front teeth | Rear teeth= Gear Ratio
16 34 = 2.125
15 32 = 2.13
16 35 = 2.19
15 33 = 2.20
16 36 = 2.25
15 34 = 2.26
14 32 = 2.28
16 37 = 2.31
15 35 = 2.33
14 33 = 2.35
16 38 = 2.38
15 36 = 2.4
14 34 = 2.42
16 39 = 2.44
15 37 = 2.47
16 40 = 2.5
14 35 = 2.5
15 38 = 2.53
16 41 = 2.56
14 36 = 2.57
15 39 = 2.6 Stock gear ratio
16 42 = 2.63
14 37 = 2.64
15 40 = 2.67
16 43 = 2.69
14 38 = 2.71
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 42 = 2.8
16 45 = 2.81
14 40 = 2.86
15 43 = 2.87
16 46 = 2.88
14 41 = 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
14 42 = 3
15 46 = 3.07
14 43 = 3.07
14 44 = 3.14
14 45 = 3.21
14 46 = 3.29
so if you want more top speed than stock settings
use 14t front and 36t rear
or 16t front and 41t rear
if you want more acceleration
use 13t front and 34t rear
or 16t front and 42t rear
BIGGER TIRES (100/80 and up): use color red
SMALLER TIRES (80/80 and below): use color blue
References: traxxas-modifier, Nov 26, 2007 Report
14/41sir, what is the best combnation sprocket for my new sniper mx 135??? all stock!![]()
im wid my stock engine sniper, sprocket (15 x 42)..tire size (80 x 70) frnt, (90x80) rear..stock pipe.. 3rd gear at 95-100kph..and 4th gear about 120kph max..if i change my sprocket to (15 x 41) is it possible that my topspeed wud increase? btw, im 85kg rider.If stock engine stay to stock sprocket combi 15/39 AFAIK
thanks
have u already tried 15 x 41 bro?15-42... 120kph normal position... sniper mx open pipe the rest stock...
not yet bro but i'm satisfied to 15-42... great acceleration... 120khp in less 1km...have u already tried 15 x 41 bro?
