Big Carb Jettings / Jet Sizes Recommendation For Yamaha T135
arep
help me please...
i use 61mm block
uma cam
BRT neo dualband
keihin PE28
i use mainjet 152/pilot 30
the spark plug still white..
i cant find plug colour brown..
jchris1124
help naman po,pag 1/2 throtle onwards po parang lunod motor ko,maitim ang sp ko
is it main jet? pilot jet? needle?
currently 180mj 17.5pj midle clip needle
Paladin
Ano ba current carb size mo paps? Kung 28mm carb mo, mali ang settings mo. Sobrang laki kasi ng MJ at maliit masyado ang PJ. No wonder ganun ang takbo ng MC mo. Try mo mgstart sa 125 MJ, 40PJ then palit palit ka nalang next size lower or higher sa initial setting na sinabi ko.
Yung ang current settings ko, kung mas maliit ang carb size mo syempre mas maliit din ang jetings.
jchris1124
thanks sa info paps.Yung ang current settings ko, kung mas maliit ang carb size mo syempre mas maliit din ang jetings.
paps salamat im using 28mm flatslide,problem ko kasi walang mabili na jet dito sa manila, mikuni TM28 carb ko. kaya un din ang problem ko where to buy jettings,wala kasi kamukha sa ibang carb e..sana may makatulong
Paladin
sa Caloocan, 10th ave. dami dun paps.
TETANUS
pareho tau ng carb bro...as of now gmit ko 130mj ,30pj...
wla pa rin sa tono,.plan ko mg 180mj,20pj...
contact mo c sir traxxas bro meron xa stocks n jetz ng tm28.
jchris1124
thanks paps,masakit sa bulsa mag experiment e,taga san ka paps? 180mj 17.5pj ako ngayon e
jchris1124
i think on 135cc-150cc using TM28 you should start with pj#17.5 - 20 and mj#185/190/195
hi sir job,im using 17.5pj and 180mj needle at center the result is ok at close upto 1/2 throtle but beyond that my bike doesnt move,rpm drops like it was drowning..what can you recomend
Laeon
pls help.. stock bore and stock head,k1 camshaft using keihin 28mm, what's the recommended jettings? TIA;)
