Big Carb Jettings / Jet Sizes Recommendation For Yamaha T135
mac kevin
small pilot jet or much af mixture
tnx bro ill try the next higher one pj... currently, the sound of my engine when stop mode, tsug tsug. tsug.. tsug...tsug.... last sound, a backfire sounds like "peeeewwwwwww" then engine stop... I saw moisture-like smoke coming out from my carb.. ang gulo... hehehe
suplado010
try mo poh muna magclockwise sa a/f baka mahabol pah...
mac kevin
hehehe, basta mikuni VM series laki ng number sa mj... kun d ako nakamali katumbas ng butas sa mj=105 or 107 standard carb natin, correct me sir traxx if im wrong
ianghol
if rounslide keihin, 115, 42 for rides
sa 115mj 42 pj san nka set ang clip ng needle jet..sakin kac sa smx running 60kph accelerating to 85 kph sa 67-80 parang pupugak ang andar..pag dahan dahan po ang aceeleration..pls help boss..thanx
suplado010
try mo muna yung standard position ng needle papa..tas kapag filing mo nabibitin sa gas ibaba mo poh ng isang gilit yung adjust ng needle...
ianghol
thanx bro..na try q na pero parang panget performance..try ko nlng ulit,,thanx ulit bro,,post ko info tapos ng another try:)
suplado010
main jet lang nadadagdagan or nababawasan kapag nagadjust ng needle..wala itong effect sa pj AFAIK..kapag nag baba ng adjust madadagdagan yung bigay ng mj tas kapag sa taas kah naman poh nag adjust sasakalin naman niya yung mj...
Stockbore
i believe that is rich needle jet. use 120 mainjet and 2nd to the top needle setting sir and 1/2 af mixture
