john_carlo
No air cleaner..what type of air filter did you used paps?..
Dagdag k sa main jetguys need your help vixion kit by gsd vixion vs cms stage 2 cams keihin pe 28 jettings mj 120 sec jet 42.5 on high rpm nag lelean sya
By checking the sparkplug burn color if it is whitish its lean if black its richhow would you na naglelean bro?
boss ibig mong sabihin pag gusto ko palitan mainjet ng stock carb ko i can use ung mga jettings pang 4k na nabibili sa mga auto supply? thanks.my bad..yung carb paps ng 4k engine,yung main jet nun ang ibig kong sabihin..
yung stock ko kasi dati from stock 105 main jet ginawa kong 110 tapos
stock pilot lang..pero nkakaibitin parin kaya nag uma 24mm ako.. :wink:
Any result sir? Ok nba mc mo?Any succesful tuner of kawahara k1??? In smx wid stock carb, stock bore, airbor with filter, modified pipe.
I did a lot of reading still no answer.:-(
my current setupBy checking the sparkplug burn color if it is whitish its lean if black its rich
what is your mc spec paps?i think we finally fix the prob. some adjustment with the air... 1 and 1/2 turn with mj 108 and pj 35 and we also change our engine sprocket to get the top accelaration match with the carb settings walla! 2nd gear can go up to 100!!! thnx to sir @ronald031803 for his hardwork!
Hi bro MX user here,Any succesful tuner of kawahara k1??? In smx wid stock carb, stock bore, airbor with filter, modified pipe.
Maybe your pj is big try the 40.. If you are afraid with the kaboom then use a bigger mj..my current setup
59mm jvt (shaved and hi-comp)
stock head
cms cams and vspring
brt hyperband
kiehin 28mm (45pj/120mj)
i havnt check my SP yet, but matakaw sobra sa gas... and my experienced after my bike got started yun minor nya mataas then few seconds nagdadrop..... its like "brom brom brom brom...brom.......brom.....brom..." and once naka rev medyo delay ang pagbalik ng minor. i dont the actual A/F mixture... sabi kasi ng mechanic ko need daw malaki ang mj jet para iwas sabog.... pls enlighten me mga paps...
thanks
up po sa question ko bka may nkaka alam.Is the needle of the VM22 stock carb of sniper classic adjustable? does it affect the throttle? right now my throttle is hard to twist. im wondering if adjusting the needle clip will fix the problem..
