Big Carb Jettings / Jet Sizes Recommendation For Yamaha T135
Sniper 03
Tnx bro. What if? If i put the lock of the needle clip on the second slot at the top of needle adjuster? I'st ok if i cannot change my jettings, just put the clip at the top? It is possible? Tnx for your info sir. :)
mobius
readjusted the carb again, from fully closed. i turned it counter clockwise 3/4ths of a turn. this is the result:
idle 15 mins:
and then for the mid-high RPM run (around 5 kilometers run back and forth):
is this the ideal color both for the ideal and high RPm run? thanks :)
still using
Keihin PE 28mm using 115 MJ and 35 PJ :)
BOSS HOW MANY TURNS PO SA A/F?
Jessie Y
My new set up:
57mm Vixion
faito low cams advance
MTRT valve spring
Stock head - P&P
BRT rcdi
26mm Keihin carb (130mj/42pj)_1.75 turn out AF
Sprocket 15/39
Fuel consumption: 42 KM/liter
Leo Vince Aluminum
Laguna to Pasay vice versa (68 kms)@ 80-100 kph_Unleaded gasoline
sniper_shit
sirs... help me decide what jet combinations should i put in my 28mm keihin carb (class a only)
with
59mm bore,
rcdi,
uma black cam,
cld valve spring
faito clutch spring,
stock head
14/39 sprocket
currently using (115mj and 35pj)
fuel consumption: 20km/liter
HELP ME MASTERS..
sniper_shit
im using jvt 59mm too bro... my jetting is 112mj and 45pj... 28mm thailand keihin with uma after market filter... =)
SIR..HOW ABOUT THE GAS CONSUMPTION? I'M ALSO A JVT 59MM USER SIR.. I HAVE A PROBLEM WITH THE GAS CONSUMPTION.. CURRENTLY USING KEIHIN 28MM CARB (115MJ,35PJ).. 20KM/LITER
Shinshan03
Current set up:
Stockbore
Vixion vspring
K1 cams
Rcdi
Keihin28 p42, m112
Tama lng po ba yung jettings ko?..need some advise..tnx
Sniper 03
Current set up:
Stockbore
Vixion vspring
K1 cams
Rcdi
Keihin28 p42, m112
Malaki masyado ang pilot. Pero depende rin try mo tingnan spark plug mo dapat brown ng sunog nya, yun ok na yun. Pag maputi kulang sa gas, pag sobrang itim sobra sa gas dapat kulay kalawang ang sunog ng spark plug mo
ransell
mine..
vixion kit
26mm keihin carb 39pj 110 mj.. di ko alam kung may mali dito pero 1/2 turn lang ung akin rich pa din..so i made it 1/4 turn ulit kanina pero n try ko n eto setting n to rich p din..kaya ko binalik sa 1/4 turn kc nag p toppet ako 04/05 so plug read ako bukas..hehehe..sa tingin ko need ko ng magandang ignition coil para gumanda ang sunog since stock p lang gamit ko..
regrind cams
brt dualband
vixion v.s
crg clutch spring
not so big elbow pipe..heheh
ang 100 pesos taguig-moa 2 days..
atlantic
I use full uma racing at my engine lc135 1st model n use a yoshimura yd mjn 28mm......can u suggest mj n pj for it mr.traxxas.....ekzos also yoshi tri oval
