Big Carb Jettings / Jet Sizes Recommendation For Yamaha T135
ESOJ de GUZMAN JR
so that's the difference between diaphragm and piston type carburetor. its there response when it squished. any piston type that support tps sir?
ransell
stock carb of sniper classic sir..but its only 22mm..but its more responsive ...or u can use other brand just do the tps poorman style by sir traxx..or use rcdi with tps support
lokaism
I need help
Vixion block.
Vixion Cam.
uma racing 28mm
pj 35 and mj 110
k&n ru 1280 air filter
cdi & coil
NGK Iridium
3,1/2 a/f but the spark plug still black, anyone help me plzzz
AJM
Pls help me
My set up is :
Stock bore
Cam 1
And vixion valve spring. What can u recoomend for my jetting? Keihin 28mm pe
kikaipitoy
yesterday i clean my 28mm OKO carb for the first time by myself found out that my jettings are 130-48.. im on a 62mm Bore, what jettings can you recommends guys to improve my gas mileage without sacrificing speed tnx...
Sniper 03
130/48 is stock jetting of oko.
Try 42 pj and 118mj then 3/4 turn air screw yan ang gamit ko ngayon with 62mm, ok naman sparkplug color rusty brown. :D
