blok 62mm uma racing
vav_mugen524
Bros, in the page 1,i saw the broken block, is that an UMA BLOCK 62mm? Sorry i cant understand your language. What can u say or experience about uma ceramic block? Thanks! Looking 4ward ur english answer..
kirawin
motoman usa hard break in:
On the Street:
Warm the engine up completely:
Because of the wind resistance, you don't need to use higher gears like you would on a dyno machine. The main thing is to load the engine by opening the throttle hard in 2nd, 3rd and 4th gear.
Realistically, you won't be able to do full throttle runs even in 2nd gear on most bikes without exceeding 65 mph / 104 kph. The best method is to alternate between short bursts of hard acceleration and deceleration. You don't have to go over 65 mph / 104 kph to properly load the rings. Also, make sure that you're not being followed by another bike or car when you decelerate, most drivers won't expect that you'll suddenly slow down, and we don't want
anyone to get hit from behind !!
The biggest problem with breaking your engine in on the street (besides police) is if you ride the bike on the freeway (too little throttle = not enough pressure on the rings) or if you get stuck in slow city traffic. For the first 200 miles or so, get out into the country where you can vary the speed more
and run it through the gears !
Be Safe On The Street !
Watch your speed ! When you're not used to the handling of a new vehicle, you should accelerate only on the straightaways, then slow down extra early for the turns. Remember that both hard acceleration and hard engine braking (deceleration) are equally important during the break in process.
terpulang nk ikot ke x...huhuh...
phl wat cara nie...cepat n berkesan...hahahhha
terbaik gak cara nie....ertinya dlm 500km da abis pantang lak ek,,;)
kirawin
yup its a UMA block 62mm, i don't know about the experience because iam using different type of block,our friend here bro MuFaF is the one using this block and maybe he can review about this block later...:).,between where are you from mugen???
kirawin
ha, bab nie yang den suko nie, bro kirawin, hantar ejos kat takim nak buat ejos perang ker macam maner???wah2, cer tgk brape takim amek???sbb nak hantar buat la...janji lawas + senyap jer....hehehehe
o, dok punchong, kira ok la tue...aku pun pernah kene tapau dgn 5 speed kat duke aritue, tapi mase standard2 la...insyallah lepas raye nie dah taknak standard, nak join geng jiwa kelajuan....hehhehehehehe, btw aku kat kl gak, bro MuFaF try usha acc baru utk meter lc baru 2011, mane la tau leh dapat yang ader rpm ker...leh baca enjin sket....ride safe bro...jgn cilok2 kat jalan biase....kat highway takper...
bro adam_john99, nk htr janji lawas...nk senyap or bising tue tgh pikir lagi...sbb exhaust yg nk htr pun nob1sss
otai2 semua yg pernah wat exhaust kat takim, nk tanya sikit...takim wat dlm sehari ke ???or kena bawak exhaust spare utk pki sementara ke???
kamen rider x
Bro Kirawin, jgn lawas sgt klau ley biar ade stopper sket baru ada UMMPHH..hehehe
-Klau lawas sgt power loose,bunyi je lebey pegi agak kureng..(Bunyi cam ribut pegi cam siput)..Wakikikiki..:D-
kirawin
kalo mcm nie..kena bawak bro kamen skl lar g jmp takim nnt...hehehehe:D
kirawin
Bro Kamen, nk tanya pasal nk wat kat takim tue....exhaust kena bwk xtra 1 ke...atau bro takim leh wat dlm 1 ari??:eek:
kamen rider x
Bro Kamen...ok, thnks for the info :)
Welcome Kirawin..;)
Klau awak nk wat kat Bro Takim tu, try tanya dulu ni no Bro TAKIM 012-272 1767,
(klau dia x tuka no lg la..)hehehehe:D
Lg 1 tmpt pro wat ejos Lc std modi road blok selalu lepas " bunyi x bising top speed pun jln" klau enjin set sme cantik...
Cari bengkel Merah Putih ade moto cub prix warna merah,cari "Bro Din" alamat search kat google map sng cari...:rolleyes:
Mentadak Kamen Bro ni yg set 100%,alhamdulillah mmg terbaek sampai skrg yg ptg "Rider pandai jaga enjin ble dah modi"..hehehe:rolleyes:
Jalan Jimat 25/87, Taman Sri Muda, 40400 Shah Alam, Selangor, Malaysia
-Ni la port Kamen "belai2 enjin selalu dulu..hanya org2 lama layan moto je kenal ni bengkel ape..Pasti "saingan" seram sejuk klau tahu..hehehe :p:p:p-
kirawin
Bro Kamen, Bro Din nie wat exhaust ngan set motor skl ke???:rolleyes: terbaik2 :p:p...
boleh lepak2 bengkel dia lps raya nnt:D...start keje kat s.alam lepas raya nnt...:)
kamen rider x
Yups..Kirawin bkn takat set je, sme dia ley wat lg2 Lc cam wat rojak je bg kat tgn dia..:p
Bg Kamen dia mmg pomen profesional tahap asia tu..
Tgk je sempoi, tapi hasil tgn dia moto main ke luar negara x m'hampakan la selalu...:cool:
Try la baik2 dgn dia,1st time jumpa mmg nmpk dia tu cam sombong sket sbb muka dia keras tp aty dia baik s'benarnya,:D
sbb dia belum knal kita lg kn..hehehe..:)
Sblm wat tu sdiakan lah p'geras nya..wakikikikiki :p:p:p
Pomen Kamen yg t'akhir..xkn tukar2 pomen lg dah mmg ni yg t'baek..;)
-Ble dah byk kuar pengeras tepat pd tgn pomen nya, lg bagus la hasil enjin dgn kuasa pecutannya..;););)-
kamen rider x
Hehehe..Insya'Allah..Yg mne saya tahu tu saya akan kongsikan bersama info2 serta tips2 jika ada..
-Dimana ada kemahuan dan usaha pasti akan ada kejayaan-
adam_john99
bro kamen, nak tanyer, mcm mane nak setting BRT Imax yang ade adjustable degree and rpm tue???tadi baru jer sambar, try degree 40 bunyi knocking and tak bley blah la...ader tips tak nak setting degree braper yang cun utk moto standard??hehehehe, moto saye standard jer, lepas2 raye baru turun enjin sket....
kamen rider x
Enjin std degree set 27-29 je jgn over set kang overdose valve tu ley putus...
Rpm 8.5k-9k je set utk std,over set lain pula jd bkn tmbh laju nti trs parking tepi pula...hehehehe :D
-Set biar ngam dgn modifikasi jgn overdose-
adam_john99
ooooOOOooo, bru jer try, best2 la..a.tq bro kamen...nak tanyer. kat mane kat KL nie nak besarkan valve ek???kalau buleh nak besarkan valve 23-21...hehehehe
