BRT or REXTOR CDI?
benramos
no offense i think your brt is a fake one, im from tabuk city, kalinga province. travelled from here to manila appromimately 512km stop only to eat and my ass is numb when i arrived at our palce in caloocan,and went back having a small race along the road kasi mag isa lang ako umuwi e.rextor and brt are both good brands tested it both youll never go wrong. wag lang peke mabibili o ahihihihihi.
:dance:
i dont think its a fake.i bought it from sir speedmaniac.do you think speed will sell fake items?
odie
trusted seller yan easy to deal with pa!,may be naton lang sayu, or there may be other factor,weak battery,fastcharger rectifier etc, been here in the forum reading and learning for almost 4 yers na rin,pero busted brt...? may be diko lang nabasa yung thread pero to be honest your the first ive read about over heating cdi,maybe i miss some cases that i did not read siguro. now im using my brt with a replaceable battery na ,if i run fast i cant use my busina because no more power na but still not busted thats for almost a year with long rides pa
audioguy
If i run fast I can't use my busina.? What do you mean by that sir.? If your bike is running 60 to 90kph the busina doesn't work anymore.?
harrish10
sir is the brt powermax battery operated? tested mine with no battery i didnt start... but before when im using brt dualband the first generation it works with no battery.. tia..
mac kevin
is there a new version of BRT powerMAX?, iv been using red powermax hyperband BRT for more than 2 years now, sa pagkakaalam ko BRT will utilize /rely power from the engine when battery is low... iv tried it several times with low battery charge and proved it coz when engine stop the battery has no power at all even horn dont sound and press start dont work.. but now, iv already changed my battery coz im afraid lowbat may affect the performance and life of my BRT CDI in the long run..:hug:
mac kevin
its true coz iv experienced it already when my positive connector was detached unnoticed, all the time u can start/run mc at first then unplug battery connection when using BRT cdi, but bro... this is to share u that one forumer here start his mc and purposely unplug battery connection, the result was BOOOMMM, BRT cdi rest in peace... luckily mine is still kicking..
audioguy
So You mean to say sir, that brt CID is battery opperated.?
mac kevin
FOR ME lang ha.. half breed kc itong c BRT, pwd sa engine kukuha ng power, pwd rin sa battery. kakalito noh hehe, but i will say, to use BRT CDI with condition battery performance wise is on top... if lowbat or drain talaga battery with no power at all aandar pa rin c snipy just use kick starter, but i hate lowbat...
audioguy
I agree...! I notice before every time I charge the battery of my MC, the response of the bike is different as it was before.... So I think we should used a good battery replacement for better performance of this CDI...
mac kevin
if u plan changing ur carb w/o hassle, go for BRT
maybe... coz some said BRT does not support TPS, is this confirmed? if so... u can easily change to big carb without the need of installing back the TPS..
rextor on the other hand, supports TPS all the time, so u cant just change to big carb unless you put back your TPS to its funcion.. so poor man's TPS is the prime option coz some big carbs dont have TPS also...
facts:
TPS is designed in assuring efficient engine operation for fuel economy, in every lift of the TPS electric signal will send to the CDI to perform its optimum and exact response to the engine;
so does it mean when using REXTOR cdi engine is in efficient operation?
how about in using BRT ? becoz u disregard the purpose of TPS
in case same engine set-up and driving style:
(just a sample question)
BS/VM22,25,26 MIKUNI paired with BRT w/o TPS= worst fuel consumption?
BS/VM 22,25,26 MIKUNI paired with REXTOR w/ TPS= better fuel consumption?
facts:
rextor is based on TPS while brt is based on RPM to perform their efficient operation. thats why brt doesnt need TPS:eek:
yes, it MIGHTdestroy your engine if you dont know how to use cuz there will be no RPM LIMIT when you rev to the max even if you installed stiffer valve spring. :DDDD thnx
