Cdi Question
jiGGer
when installing valvespring and rcdi, do we have to rejet the carbs?..is there any connection between them?..how about the valve clearances?
jordan
sir sa brt na dualbrand. if orange ang light yan ay normal mode? if blue will blink2 race mode? tnx
thon
can you estimate me the rpm can give with rcdi and v.v.spring??
Engine RPM will depend on your engine modifications(bigger valves,carb,ignition coil,higher lift cams,spark plugs,etc).Using RCDI will remove rev limiter and aftermarket valve spring will prevent valve float.
febe gienel celebria
so sir even i change rcdi and rvalve.. power and speed of my mc will increased?? hw many percent?? only rcdi and rvalve r change.. and open pipe.. the rest r stock..
emerson
this mode what i only wanted for my bike, can someone qoute me for R.CDI,V.spring,open pipe,sprocket combination, and please attach wha brand you recommend my bike is sniper MX, TIA...
same wid u sir emerson.. i want only minor modification.. for now i can reach 120.. open pipe all stock.. maybe f i hav rcdi and rvalve spring.. can reach 130kmh..
audioguy
im using powermax hyperbnd. but my spring was stock. im waiting for sir traxx for my vixion. bt my question was hnahataw ko na. safe lng po b un basta hwag lng mag over rev? i also has namban cam. hnd po ba ako matutukuran ng valve?.
sir john just want to ask po... kumusta experience mo w/ cdi using stock valve-spring,, inuna ko lang kasi brt dualband cdi,, then plan to go for vixion by dec.. ok lang ba kahit stock lang valve spring ko for now? thanks in advance..
