thon
Rextor cdi & CMS valve springwhat is the best brand for the combo of rcdi and valve spring?
can you give me the price range of this items?Rextor cdi & CMS valve spring![]()
I dont know the current market price of rextor CDI and CMS valve spring. Just Pm Sir Traxx , Kr.r_sniper ,Boss_jay316 for price inquiry.can you give me the price range of this items?
thanksI dont know the current market price of rextor CDI and CMS valve spring. Just Pm Sir Traxx , Kr.r_sniper ,Boss_jay316 for price inquiry.
Hi sir!!!! I want to try the same thing you want, valve spring and racing cdi.. do you have it already? how is it.? give me feed back naman thanks!!!salamat mga papz...now i have idea....tnx again
Engine RPM will depend on your engine modifications(bigger valves,carb,ignition coil,higher lift cams,spark plugs,etc).Using RCDI will remove rev limiter and aftermarket valve spring will prevent valve float.can you estimate me the rpm can give with rcdi and v.v.spring??
so sir even i change rcdi and rvalve.. power and speed of my mc will increased?? hw many percent?? only rcdi and rvalve r change.. and open pipe.. the rest r stock..Engine RPM will depend on your engine modifications(bigger valves,carb,ignition coil,higher lift cams,spark plugs,etc).Using RCDI will remove rev limiter and aftermarket valve spring will prevent valve float.
this mode what i only wanted for my bike, can someone qoute me for R.CDI,V.spring,open pipe,sprocket combination, and please attach wha brand you recommend my bike is sniper MX, TIA...so sir even i change rcdi and rvalve.. power and speed of my mc will increased?? hw many percent?? only rcdi and rvalve r change.. and open pipe.. the rest r stock..
same wid u sir emerson.. i want only minor modification.. for now i can reach 120.. open pipe all stock.. maybe f i hav rcdi and rvalve spring.. can reach 130kmh..this mode what i only wanted for my bike, can someone qoute me for R.CDI,V.spring,open pipe,sprocket combination, and please attach wha brand you recommend my bike is sniper MX, TIA...
more than 130?? even i only change rcdi and v.spring?they if we install r.cdi and v.spring they think we can reach more than 130kmph.
wapin..BROTHERS, BE PERSISTENT READINGS POSTS....
ALL A's ON YOUR Q's ARE THERE FOR GRABS..
HAVE A NICE DAY.!!!![]()
sir john just want to ask po... kumusta experience mo w/ cdi using stock valve-spring,, inuna ko lang kasi brt dualband cdi,, then plan to go for vixion by dec.. ok lang ba kahit stock lang valve spring ko for now? thanks in advance..im using powermax hyperbnd. but my spring was stock. im waiting for sir traxx for my vixion. bt my question was hnahataw ko na. safe lng po b un basta hwag lng mag over rev? i also has namban cam. hnd po ba ako matutukuran ng valve?.
