CMS camshaft inquiry
turbulence
Bumili ako ng CMS camshaft. Gaano po dapat kalalim ang valve pocket ko kung kinekelangan at ano magandang tappet setting?
rowan
yup gamit ko 2 mos na . pocket ka lng for safe reason. ok yan basta kasama mo lng v spring. dahil kng wala, valves mo masira like my friend mahilig bumirit la naman valve spring. mahal pa naman exhuast valve sa yamaha 3s.
vav_mugen524
Dpat tlaga may v.Pocket kasi long durati0n xa. 5.8mm lift at 280 deg. durati0n. 2-3mm deep dapat kasi nag eexpand and aluminum or bakal kung umiinit.
rowan
@ turbulence = ayan may naka add pa so mag valve pocket ka talaga tanx kay vav_mugen524
so far sa akin okie pa rin 2mm no base gasket .
vav_mugen524
Bro rowan bakit exaust valve ang natatamaan sa CMS CAMSHAFT? Karamihan na cams ay sa intake valve?
300 degrees daw ang durati0n ng CMS cams kaya neEd talaga ng valve pocket.
rowan
its my friend,s bike . dunno why exhaust valve , basta AFAIK hindi xa naka valve spring. i know nka pocket xa but same results
ex valave nya tinamaan parin. dunno why.
mine 2mm pocket lng no problem naman
RTG
my bike also using CMS cams and CMS v. spring w/o V. pocket - . so far so GOOD
Q : Do a Valve pocket can Affect compression / performace ?
Thanks
RTG
Thank bro .
in my current setting there are possibilities to hit the Piston head ?
And where is the Trusted Machine shop / mechanics to do a perfect v. pocket ?
