lowell laurente
Patulong nmn po mga bossing,,, plano ko po kasi mag convert diskbreak eh hindi ko po alam anong kit dapat bilhin s RB 8 spoke po n mags ko,,, Ano po b dapat? Kailangan pa po bang machine shop ung RB 8 spoke? salamat po,,
depens what rb are you using, is it the disc ready or the drum type 8 spoke... there are so many topics regarding converting into disc brake just use the serach function..Patulong nmn po mga bossing,,, plano ko po kasi mag convert diskbreak eh hindi ko po alam anong kit dapat bilhin s RB 8 spoke po n mags ko,,, Ano po b dapat? Kailangan pa po bang machine shop ung RB 8 spoke? salamat po,,
care to share some pix bro.. for reference..or you can buy a "Option One Rear Disk Conversion Kit" 4k++ no need to convert ur mags or puncture a hole on it,...
its plug and play as what the seller in caloocan said,...
@lowell laurentecare to share some pix bro.. for reference..
@lowell laurente
Option 1 rear disc brake conversion kit cost 4.5k at cyclone. No need to drill a hole on your brake drum mags. Here's reference picture.
View attachment 18463 View attachment 18464
how does it able to hold on to the brake drum mags?.. i wonder.. does it use a magnet?..heheyou need to bore a hole when using rb rear brake kit right,..
unlike in option one its plug and play,...
oh copy bro, do you have it installed on your mags?.. im just too curios hehe..sorry i didnt see how it look like maybe, if you can see the picture above, the rotor disk is attached to a hub same size of our mags,...
correct me if i'm wrong,.. maybe the inside part of it is adjustable, you can tighten it so it will hold the inside part (same as our drum brake principle)
the seller said no need to punch a hole,...
np bro.. juz doing my share..
using a racing boy disc ready mags with rb brake kit its plug and play no more making holesyou need to bore a hole when using rb rear brake kit right,..
i see, i thought that you need to make a hole in your mags so that you can place the rotor hub,...using a racing boy disc ready mags with rb brake kit its plug and play no more making holes
