Diskbreak Convertion Question
Storm_rider
thon thanks for the image,... it seems that after number 2 you will place number 3 which serves as a stopper, and number 4 will lock it into place
as you tighten the screw, number 3 will expand and makes contact to the inner part of the rim which holds it,...
john_carlo
i see, i thought that you need to make a hole in your mags so that you can place the rotor hub,...
how will you connect it?
as i see on the actual product you need to bore 4 holes in your mags to place the hub,
rb disc ready mags same as thx1r mags that has a hole fixed for the rb rotor
john_carlo
i thought they were talking aboun NON diskbrake ready mags,..?
because if it is disk brake ready then the ts wont ask for a conversion process.
the TSs didnt mention that his rb 8 spoke is disc ready or not..
BTW here the conversion of brembo caliper to stock mags and rb brake kit to drumbrake this convertion is with hole on the mags:)
bintoy
anybody there who is selling this kit? i want to buy one. i don't want to drill holes kc sa stock mags ko baka masira lang sa katagalan
mark602
patulong boss. mags ko kasi is 3spokes racingboy.drum brake. bumili ako ng rb brake system set. anong conversion kailangan kong gawin?
john_carlo
Better buy a disc ready mags.. Coz converting the drum brake mags will hit the rb caliper.. See my post pix above i shave the mags so that it will not hit the caliper
jangbest
Sad to say you cannot use that RB Rear disk system to your Drum Brake RB mags, That RB Rear Disk braje system is intended to Disk Ready RB mags.
AFAIK ...
