DIY: 20 LED display Tachometer for Sniper 135
Sidro
Sana paps makagaw ka ng buong kit na 4 sale.. hehehe....
Paps lang some tech info, balak ko palitan LED yung park light. ano ba ma suggest mo na value ng resistor para i series sa LED para hindi mabilis mapundi. I mean single LED lang kasi gagamitin ko yung jumbo size...
EinVer
assuming na umaabot din ng 16volts ang motor mo, 1K ohms ang safe resistor para sa single LED
mas maganda kung gagamiti ka ng voltage regulator like AN7810
para steady 10volts lang ang magiging supply ng LED
saka gamitang ng resistor na mas mababa value like:
470 ohms - for blue or white LED
560 ohms - green, yellow, red
sa parklight ng sniper ko, 2 LEDs in series, 68 ohms resistor, at AN7808 (+8volts regulator) ang gamit ko, so far ok pa rin
EinVer
traxxas-modifier said:
bro design the IDLE TUNER and SHIFTER LIGHT
to help fellow t135 owners
nag try po ako gumawa ng bagong design para dyan sa suggestion nyo.
info's gathered:
- mahirap magtantya/timpla ng idle rpm with just 1 LED, maybe with 2 or 3 LEDs pwede but with just 1, its kinda hard.
- shift light however seems to function as it should, it lits up when you need to shift hehe
i think i'll use 2 (green, red) or 3 (green, blue, red) small LEDs for it para mas
pero only 1 LED lits at a time, para mas madali marecognize yung LED color
advantages:
- less wires
- more compact
- perfect shift all the time (para sa mga resing resing mode hehe)
disadvantages:
- hindi ko alam kung saan ilalagay yung mga LEDs, panget kung nakatiwangwang lang hehehe
haven't tried it with RCDI, stock lang kasi ako
maybe i'll make another one for someone with RCDI, any guinea pigs? este volunteers out there? hehe
material costs lang sa inyo, ako na bahala mag-assemble :wink:
Sidro
thanks paps Einver
jerkyboy613
EinVer said:
para po sa mga mahilig mag DIY dyan with electricals/electronics
(dito ko po pinost sa Country Specific forum, ayaw ko kasi mag english hehe)
technically speaking, analog display po sya, since huhulaan mo kung anong rpm ka na
but this is digitally driven, kaya hindi sya aagaw ng power from ignition coil gaya ng ginagawa ng mga analog tachometer na nabibili sa caloocan (e.g. type-r)
di bale 2 parts po ito, yung una LM2917 IC para sa pickup ng rpm signal from ignition coil/cdi, then output as voltage (frequency to voltage)
yung 2nd is cascaded LM3914 LED display driver to translate the voltage from LM2917 to LED display
kahit hindi nyo maintindihan yung info above, basta makuha nyo tong schematics, okay na :)
eto po schematics:
LM 2917
LM3914
in my case, 18 LEDs lang ginamit ko
yung 17th LED ko ay 3mm super bright white para madaling mapansin
this indicates my timing for a good shift
18th LED is 3mm super bright blue, mas agaw pansin to kesa white
mabilis lang kasi yung paglipat ng ilaw kapag humahataw ka, kaya ang dating nyan eh parang nag blink twice ng malakas yung tacho meaning time to shift up :)
adjustable po thru a variable resistor yung limit (yung malaking bilog na may arrow at 500k ohms rating sa LM2917 circuit)
para kahit naka after market CDI ka with no limit, pwede mo i-adjust para hindi ka mag over rev
pics:
bread board prototype ng LM2917
laying out the wires
under the panel
panel outcome (wala pang gear indicator)
Video results:
http://www.youtube.com/watch?v=PqvCdLXnKDc
[video width=425 height=344]http://www.youtube.com/v/PqvCdLXnKDc[/video]
http://www.youtube.com/watch?v=Yps4NjA4ofI
[video width=425 height=344]http://www.youtube.com/v/Yps4NjA4ofI[/video]
edit:
hindi po ako expert sa electricals/electronics
yung design ay kinuha ko lang sa datasheets ng LM2917 at LM3914
may iniba lang ng konti sa values at wirings para mag work sa Sniper 135
feel free to correct my mistakes
isa kang HENYO sir! :shock: galing mo!!! :D two thumbs up!!
DeViLsToRm
GALING SIR!!!!.. NGHAHANAP AKO NG GANYAN SA CALOOCAN LA AKO MAHANAP KAW LNG PALA MAKAKASOLVE.. HEHE GALING.. TRY KO PAGAWA SA KAKILALA KO N TECHNICIAN..
neilryu04
EinVer
Waiting mode for a plug and play panel for a Modified Sniper. Pls. PM me if actual panel is available including the price. Thank you!:D
Cris Duarte
Thumbs up syo sir.. mganda mg business nyan sir @ sniper mu narin ang modelo hehe.. sir sna magkatotoo, @ malamang dami papagawa nyan syo @ isa nko dun ^_^
Up
Up
Up
joza18
Hello, Can this tacho work on 2T scooter with 1 cylinder and CDI ignition?
I do it a this, and on Vout is always 0V. I connect a input Ignitio coil/CDI wire to charge coil wire, and nothing happen. I tryed to connect it on my pickup wire, and nothing happen.
Please could you help me?
Thank you!
EinVer
@joza18 - yes it should work on 2T scooters as long as it uses CDI.
try to change the trim pot from 500k to 1M ohms.
the V out should give you a range from zero to 3 volts depending on the rpm
joza18
Thanks for you reply.
I tryed with yours, and few others schematic with lm2917, and no one working.
How many Volts is on your ignition coil wire? On my is 150-200VAC.
Is this correct position for diodes?
EinVer
yup, that should be the correct position for the diodes, make sure youre attaching it to the wire of the ignition coil that comes from the cdi,
if that doesnt work, connecting it to the wire that comes from the pulser to the cdi.
my diagram for the lm2917 is basically the same from most datasheets available online, the values are just tweak to match our t135
