Engine related information
charge
Bore and Stroke concepts:
When bore / stroke >1.04, it is called oversquare engine.
When bore / stroke < 0.95, it is called undersquare engine.
When bore / stroke between 0.95 - 1.04, it is called square engine.
OVERSQUARE ENGINE
An oversquare engine is generally more reliable, wears less, and can be run at a higher speed. This type of engine doesn't suffer from power, but low-rpm torque does to some degree. An oversquare engine cannot have as high a compression ratio as an understroke engine at same CC. This causes the oversquare engine to have poorer fuel economy, and somewhat poorer exhaust emissions.
UNDERSQUARE ENGINE
An undersquare engine usually has a lower redline than an oversquare one, but it may generate more low-end torque. In addition, it can have a higher compression ratio to a same CC oversquare engine. This also equals better fuel economy. An undersquare engine does not overheat as easily as similar oversquare engine. However, a longer stroke usually means greater friction, a weaker crankshaft, and a smaller bore means smaller valves which restricts gaseous exchange. Luckily, with the aid of modern technology, these are not the large problems that they used to be.
* Honda CBR150 is an oversquare engine with very short strokes. That's why it can rev so high but the bottom line torque is pretty weak.
* 135LC is a slightly undersquare engine (near to square engine, which is the most balance). That's y our bike have good torque and able to rev pretty high :)
Source: http://en.wikipedia.org/wiki/Stroke_ratio
charge
MISCONCEPTION ON PORT & POLISH
It is popularly held that enlarging the ports to the maximum possible size and applying a mirror finish is what porting is. However that is not so. Some ports may be enlarged to their maximum possible size (in keeping with the highest level of aerodynamic efficiency) but those engines are highly developed very high speed units where the actual size of the ports has become a restriction. Often the size of the port is reduced to increase power. A mirror finish of the port does not provide the increase that intuition would suggest. In fact, within intake systems, the surface is usually deliberately textured to a degree of uniform roughness to encourage fuel deposited on the port walls to evaporate quickly. A rough surface on selected areas of the port may also alter flow by energizing the boundary layer, which can alter the flow path noticeably, possibly increasing flow. This is similar to what the dimples on a golf ball do. Flow bench testing shows that the difference between a mirror finished port and a rough textured port is typically less than 1%. The difference between a smooth to the touch port and an optically mirrored surface is not measurable by ordinary means. Exhaust ports may be smooth finished because of the dry gas flow but an optical finish is wasted effort and money.
The reason that polished ports are not advantageous from a flow standpoint is that at the interface between the metal wall and the air, the air speed is ZERO (see boundary layer and laminar flow). This is due to the wetting action of the air and indeed all fluids. The first layer of molecules adheres to the wall and does not move significantly. The rest of the flow field must shear past which develops a velocity profile (or gradient) across the duct. In order for surface roughness to impact flow appreciably, the high spots must be high enough to protrude into the faster moving air toward the center. Only a very rough surface does this.
charge
CYLINDER HEAD PORTING
Cylinder head porting refers to the process of modifying the intake and exhaust ports of an internal combustion engine to improve the quality and quantity of the gas flow. Cylinder heads, as manufactured, are usually suboptimal due to design and manufacturing constraints. Porting the heads provides the finely detailed attention required to bring the engine to the highest level of efficiency. More than any other single factor, the porting process is responsible for the high power output of modern engines.
This process can be applied to a standard racing engine to optimize its power output as well as to a production engine to turn it into a racing engine, to enhance its power output for daily use or to alter its power output characteristics to suit a particular application.
The internal aerodynamics involved in porting is counterintuitive and complex and absolutely requires an air flow bench, a thorough knowledge of the principles involved and use of engine simulation software in order to determine what needs to be done to optimize a port.
Although a large portion of porting knowledge has been accumulated by individuals using "cut and try" methods over time, the tools and knowledge now exists to develop a porting design with a measure of certainty. Porting by inexperienced individuals without a full understanding of the fluid dynamics of the process still continues but the results are spotty and the process is expensive and time consuming with many more failures than successes.
http://en.wikipedia.org/wiki/Cylinder_head_porting
charge
A few ways to increase engine output.
Air filter and exhaust
Increase the torque on all RPM slightly. High RPM will have more benefit since it usually suffers from lack of airflow.
Increase carburetor output
Increase torque on all RPM slightly. It might not be efficient because the total airflow in engine remains unchanged. We are just pumping more petrol to make it go faster.
Squish Band method
Increasing the torque on all RPM, due to higher compression ratio.
Increasing the stroke
Increasing the torque especially on low-mid RPM. However, engine will become less smooth at high RPM.
Increasing Bore size
Increased the torque on high RPM, engine will attain more power. Low-Mid will still benefit, but not as much as high RPM.
Cylinder Head Porting
Very beneficial for high RPM torque, but need real expert to modify for us.
Use racing CDI
Increase the ignition efficiency especially at high RPM. It also allows much higher redline. Since horsepower is directly related to RPM, revving above 9000rpm allow us to gain extra BHP.
Change to racing camshaft, valves and crankshaft
Allow the engine to rev higher with better reliability. Need to pair with racing CDI, else it is pretty useless.
charge
From the engine dimension of 135LC, my opinion is to increase high RPM power, since we already have pretty good low-mid RPM torque.
Mild modification
- change air filter and exhaust.
- change to racing CDI.
- expected result: slightly higher output at high rpm & slightly better engine response.
- combining with bigger rear sprocket can increase the acceleration further while maintaining almost same top speed before mod.
Heavy modification
just use all the mods above, lol. Just becareful with cylinder head porting.
I am planning to go for stage one modification only (Mild Mod), but using bigger rear sprocket since I don't need high top speed. Later on maybe change camshaft, valves and crankshaft.
I'll only increase the bore size if can find 60mm Forged Piston (is V-ixion having 60mm?)
135lcSS
yeah..im kinda shocked :shock: ...thank u teacher..i'll go back and rehearse 8) hehe...hmm change K&N air filter and NOBI SSS should be correct..
John
hehe sure will find me some good air cleaner,exhaust and racing cdi...any recommendation?professor?
charge
I am no teacher or professor. I always like to find out as much info as possible so that I don't get cheated by shops. Well, i guess this is a bad habit of an engineer :p
Seriously I know nothing much on the parts. There are many professionals here who knows almost every brands. I am sure they can give a lot of good reviews and feedbacks :)
Mas Catoer
Hehe Charge..
So far that I've known, most of the guys in the shop or workshop (not all) might turn to be an asshole against us when they find out that we know much about the stuff. Then s'times they cover up their lacks with very defensive reasoning.
charge
Mas Catoer, you are damn right. Actually most of the time I would like to ask them to mod according to my specification, instead of let them decide. I want their workmanship bcoz I am lazy and lack of hands-on experience, hahaha.
135lcSS, i am an electronic engineer. I learnt many tunings theories (esp. cars) from my mechanical / car engineering friends. I am trying my best to see how I can apply these knowledge into our bikes and share them here, although I am not pro in this field. ;)
charge
Every job is tough brudders. The higher salary the more stressful it is man... If I have good life, can buy Yamaha R1 and drag with any of the monsterious Skylines on the road ady, lol.
anyway, back to topic. Maybe we can list down which shops are good in engine modification in this thread.
