F/S Faito Racing Products from Malaysia
kr.r_sniper
check your parcel status Via SMS :D
To track your packages just key in LBC |space| TRACK |space| TRACKING NUMBER and send to 29762 for ALL NETWORKS
UP
Mykel
sir kent, request lang po, sir baka pdeng paki lagay sa price list nyo yung mga faito parts na pwede sa sniper mx, tnx ng marami
kr.r_sniper
wag na natin sabihin faito parts :D bahala kayo pumili kung anung brand ang gagamitin nyo :D basta kami happy kmi sa piyesa namin!!!
e2 ung mga parts na swak sa SMX galing ng OLD Sniper as per Mechanic na gumawa na ng SMX
Buong HEAD Cylinder Parts
Head
Cams
Valve spring
Valve Set
Bore kit
Ignition Coil (Universal)
HTW Plug wire (Universal)
CDI
Clutch Spring
Clutch plate (Not Confirm,sa manual kxe same eh 2010 at 2011) :D
alx.cruz
:rolleyes: :D malakas na ung Motmot mo :D ipaubaya mo na skin :p malulupet tuner mo dyan :D
sarap niyan papa kent, buwan buwan iba set ng motor mo... hehehe...
hindi na ako magugulat pag ganito na set ng motor mo...
papa Kent Sniper 185.76 cc - Infinity Block + Jack-up crank, with Racing gear set, big valves cylinder head, at marami pang iba na pang pa mamaw na piyesa... :D
kr.r_sniper
Ay Settings ata ng MOTOR mo yan :p target today hanap ng Mikuni Carb Jettings :D
kr.r_sniper
FAITO AVAILABLE PRODUCTS PRICELIST on LIMITED STOCKS
ALL ITEMS @ NEW PRICE
ALL BOLD LETTERS @ BIG DISCOUNTED PRICE...CALL OR TEXT FOR SURE BUYER...
Racing Gear Set (Tranny Set) = 9,000 "DISCOUNTED" (4pcs)
Crankshaft 3.5mm Jack up = 8,500 for H/C & 8,000 for A/C "DISCOUNTED" (2pcs H/C & 2pcs A/C)
Faito Infinity Block 60mm kit = 3,800 "DISCOUNTED" (4pcs)
Turbo Camshaft = 2,500 "DISCOUNTED" (4pcs)
S4-Evo Camshaft = 2,000 "DISCOUNTED" (5pcs)
Ignition Coil 7400 = 1,500 "DISCOUNTED" (9pcs)
Clutch Spring Zero = 600 "DISCOUNTED" (12pcs)
Engine Valve set Titanium = 2,600 "DISCOUNTED" (5pcs)
Engine Valve set = 1,600 "DISCOUNTED" (4pcs)
Racing Clutch Carrier Bushing = 200 "DISCOUNTED" (3pcs)
Racing Engine Bearing set = 1,800 "DISCOUNTED" (1pc)
Clutch Plate Thunder (2010) = 2,100 "DISCOUNTED" (4pcs)
Clutch Plate Swift-Z = 900 (12pcs for 2006-2009/5pcs 2010)
Racing Disc Break Pad GOLD (2piston) = 1,200 "DISCOUNTED" (5pcs)
Racing Disc Break Pad PLATINUM (2piston) = 2,000 "DISCOUNTED" (5pcs)
H.I.D Mini Bulb (BLUE or WHITE) = 600 "DISCOUNTED" (1pc Violet Blue only)
Faito Special Gasket = 650 (Free if you Buy Faito bore kit + Crankshaft)
Faito Plug wire = 600 "DISCOUNTED" (5pcs)
Plug Cap = 330 "DISCOUNTED" (20pcs)
21T 4th gear = 1,600 (4pcs)
Stock Connecting Rod Set = 2,400 "DISCOUNTED" (10pcs)
Gear Set 1st,2nd & 4th = 3,400 "DISCOUNTED" (5pcs)
Kr.r_sniper Location
1st step: go to maps.google.com
2nd step: enter this 14.630131,121.069044 on the search the map bar then enter...
CALL OR TEXT 09286144241 PLEASE RESPECT NO LOW BALLERS & BOGUS BUYERS..THANKS T135
NOTE: For Pick up only within Metro Manila,if outside Metro Manila Door to door delivery thru LBC or AP Cargo "Visayas & Mindanao only"...thanks
kr.r_sniper
Clutch Plate Swift-Z (06-09/2010) = 900 (12pcs for 2006-2009/5pcs 2010)
More Items Coming...Check my other Threads :D
