F/S Faito Racing Products from Malaysia
kr.r_sniper
May option ba na sa AHM pipe na pede maingay pede rin hinde.... kusto ko tahimik lang kasi hehehe.
Yup meron DB Killer ang AHM Exhaust system sa package except AHM M1-SP GP Type & AHM CF GP Type...bsta GP Type Exhaust system eh walang DB Killer kxe for Racing use only :p
kr.r_sniper
FAITO AVAILABLE PRODUCTS PRICELIST on LIMITED STOCKS
RFS: Need Funds...Thanks
ALL BOLD LETTERS with BLACK COLOR FONT @ BIG DISCOUNTED PRICE...CALL OR TEXT FOR SURE BUYER...
Racing Gear Set (Tranny Set) = 8,700 "DISCOUNTED"
Crankshaft 3.5mm Jack up = 8,000 for H/C & 7,000 for A/C "DISCOUNTED"
Faito Infinity Block 60mm kit = 3,500 "DISCOUNTED"
Turbo Camshaft = 2,500 "DISCOUNTED" (4pcs)
S4-Evo Camshaft = 2,000 "DISCOUNTED" (5pcs)
Ignition Coil 7400 = 1,500 "DISCOUNTED" (9pcs)
Clutch Spring Zero = 600 "DISCOUNTED" (12pcs)
Engine Valve set = 1,600 "DISCOUNTED" (4pcs)
Racing Clutch Carrier Bushing = 200 "DISCOUNTED" (3pcs)
Racing Engine Bearing set = 1,600 "DISCOUNTED"
Clutch Plate Thunder (2010) = 2,000 "DISCOUNTED" (4pcs)
Clutch Plate Swift-Z (06-09/2010) = 900 (12pcs for 2006-2009/5pcs 2010)
Racing Disc Break Pad GOLD (2piston) = 1,200 "DISCOUNTED" (5pcs)
Racing Disc Break Pad PLATINUM (2piston) = 2,000 "DISCOUNTED" (5pcs)
Faito Special Gasket = 650 (Free if you Buy Faito bore kit + Crankshaft)
Faito Plug wire = 600 "DISCOUNTED" (5pcs)
21T 4th gear = 1,600 (4pcs)
Stock Connecting Rod Set = 2,400 "DISCOUNTED" (10pcs)
Gear Set 1st,2nd & 4th = 3,400 "DISCOUNTED" (5pcs)
1st step: go to maps.google.com
2nd step: enter this 14.630131,121.069044 on the search the map bar then enter...
CALL OR TEXT 09286144241 PLEASE RESPECT NO LOW BALLERS & BOGUS BUYERS..THANKS T135
NOTE: For Pick up only within Metro Manila,if outside Metro Manila Door to door delivery thru LBC or AP Cargo "Visayas & Mindanao only"...thanks
noi
sir kent keylan nxt stocks ng titanium valve spring?
pls pm me nlng kong meron na ha...... tnx nd merry xmas
kr.r_sniper
copy :D
@ALL
3,400 60mm Bore kit 25pcs available :D
UMA Bore kit 62mm Ceramic Coated also available & Vi-xion kit 57mm w/Head Gasket...
