blackknightrealms
Uy!yan ba yung kwento mo sa akin kanina??mamaw yan! lumalamon ng ibang MC!Thanks sir...oh pra sa mga nagtatanong anung motor ba ung sinalpakan ni blaster ng faito products
2009 SNIPER & 2011 SNIPER MX
ahahahaha...nagtext oorder daw cya pang dashUy!yan ba yung kwento mo sa akin kanina??mamaw yan! lumalamon ng ibang MC!![]()
superb daw ang performance
CMS versus Vi-xion...CMS is Aftermarket parts use for Racing while Vi-xion is OEM parts "STOCK" parts to be exact...in performance & quality not the same because CMS is BUILT for RACING PURPOSESisang balita.. sniper na mamaw nagkalat sa lansangan kumakain ng huwanpepte.. hahaha.. joke lang po.. up for a good seller..im still waiting for Valve spring ng faito.. kung wala pap's let me know the diff between cms vs vixion valve spring para masama na sa wish list
PM nyo na lng po si Boss Jhay pra sa CMS Products
wala pa kxe aq nyan
Wala pang stock ang Faito pra sa Belang150/Raider150....ng undergo pa ng research and development stage...angas ng R150hi sir, ako po yung nag-inquire late last night, ano po kayang pinakamainam na pwede nyo mairekomenda? salamat.![]()
Twin Cam turbo Cams...sibak tyo malamang dito
wapak
Naku SAFETY FIRST TYO...BE A RESPONSIBLE RIDER "RACE ON TRACK NOT ON STREETS"Tuloy tuloy na ang hataw nito sir KR. mag kakalat na yung mga mamaw!
faito VSpring pap's walang balita?CMS versus Vi-xion...CMS is Aftermarket parts use for Racing while Vi-xion is OEM parts "STOCK" parts to be exact...in performance & quality not the same because CMS is BUILT for RACING PURPOSESPM nyo na lng po si Boss Jhay pra sa CMS Products
wala pa kxe aq nyan
in terms po ng DURATION nagkakatalo ang CMS at TURBO CAMSanu b mas in faito turbo or CMS cams??? ehehehehehe
pra reysing reysing
negative ung Faito Valve springs eh...sir meron po link tungkol dito sa turbo cams for r150? yun po bang twin core wire yun ba yung htw ng faito? nais ko po sana kasing umorder nito kasama yung r.ignition coil 7400 series. salamat.Wala pang stock ang Faito pra sa Belang150/Raider150....ng undergo pa ng research and development stage...angas ng R150Twin Cam turbo Cams...sibak tyo malamang dito
wapak
ung tungkol sa links wala posir meron po link tungkol dito sa turbo cams for r150? yun po bang twin core wire yun ba yung htw ng faito? nais ko po sana kasing umorder nito kasama yung r.ignition coil 7400 series. salamat.![]()
secret po kxe nila un
ung sa twin core spiral opo yan ung HTW Plug wire ng Faito...no need ng gumamit ng with groundstarp na racingcoil
heheheheCOPY...Sir,
The block order has been confirmed already earlier. 60, 62 or 65 better. One more set of the lightened valves for Ian and maybe you can throw in a piston for his 60mm block kit.
Regards
Blaster
