KupaX1r
ang mahal kc kpg set ng tranny eh,,of course.... merun yta si kent na benibenta dyan set of gears yta
Mamaw na ohup up sa seller na marami ng pinasayang buyer
Meron na aq complete kit
paps anong complete kit yan?Mamaw na ohMeron na aq complete kit
set na para sumibak ng raider150, mga 2 poste... ata hehehepaps anong complete kit yan?![]()
Eto po bropaps anong complete kit yan?![]()
Package dyan 9.5k meron kn Turbo Camshaft or 9k S4 Evo
isasalpak mo na lng + Head Works...Free Shipping Limited Stocks
Merry Christmas...ung ibang kikitain ko dito ilalagay ko sa RFC Ride ng T135
Nakatipid ka na...Nakatulong ka pa...Make it happen
Post ko sa Discounted Thread
paguwi ko cguro pde na...
papa nabsa mo ba ung msg ko sa bolts and nuts..?YUPUP... kelan kaya ako hehehepaguwi ko cguro pde na...
YGPMpaps pa pm ng vix kit only? thx!
ang dami mo kxeng motorup for your items.
avail ako pag tapos na gastusin ko sa ibang motor.
Eto PricelistFAITO AVAILABLE PRODUCTS PRICELIST on LIMITED STOCKS
ALL ITEMS @ DISCOUNTED PRICE PM ME FOR MORE INFO...Thanks
Racing Gear Set (Tranny Set) = 10,500
Crankshaft 3.5mm Jack up = 7,500
Turbo Camshaft = 2,800
S4-Evo Camshaft = 2,400
Ignition Coil mini = 1,400
Clutch Spring Zero = 600
Engine Valve set = 2,100
Racing Clutch Carrier Bushing = 400
Racing Engine Bearing set = 1,900
Clutch Plate Thunder (2010) = 2,600
Clutch Plate Swift-Z (2010) = 900
Racing Disc Break Pad GOLD (2010) = 1,400
Racing Disc Break Pad PLATINUM (2010) = 2,100
H.I.D Mini Bulb (BLUE or WHITE) = 700
Main Jet #110 = 150
Pilot Jet #35 = 100
ITEMS COMING BEFORE END OF THE MONTH...
Faito Infinity Block 60mm kit
Faito Special Gasket
Faito Plug wire
Faito Crankshaft
Kr.r_sniper Location Click the LINKS
http://maps.google.com/maps/ms?msid...&ll=14.630118,121.068523&spn=0.002255,0.00515
CALL OR TEXT 09286144241 PLEASE RESPECT NO LOW BALLERS & BOGUS BUYERS..THANKS T135
NOTE: For Pick up only within Metro Manila,if outside Metro Manila Door to door delivery thru LBC or AP Cargo...thanks
may Discount pa sa T135 Boys
hahaha.ang dami mo kxeng motor![]()
5pcs lng ung engine bearing ehhahaha.
oo nga eh.
ano pala kasama dun sa engine bearing set?
as in lahat ba ng bearing yun?
kasama camshaft bearing? or yung bearing lang sa gitna?
ndi ko naitanong sa mekaniko kung anu anu ung pinalitan pero ung dalawang malaki eh sa flywheel un
ung cams ko lhat may bearing na
ndi complete set ng bearing kxe ang daming bearing sa loob lalo na ung maliliit
Also Available Racingboy Products
Racingboy Rearbreak system 6,000 complete set
Racingboy Front Alloy Big Disc 3,500 with bracket Flower type ung disc 300mm
By kr_rsniper at 2011-06-25
sir pa pm if may naka sale kayong front disk brake sir at yong Faito nah sprocket set magkano at anong size available?..thanks
kulata...
