F/S Faito Racing Products from Malaysia
kr.r_sniper
hehehehe.. hinde nman sir :D marami pa kulang gears pa hehehe all engine muna ko sa ngaun eh more on stock looks.. di pa nka RS,FE,Engine cover, stock looks lng muna pero good performance hehehe
OKIES PAPI...GOOD LUCK...anyway Hindi ko alam kung uubra ung Crankshaft ng Faito sa SNIPER MX :D
kr.r_sniper
FAITO AVAILABLE PRODUCTS PRICELIST on LIMITED STOCKS
ALL ITEMS @ DISCOUNTED PRICE PM ME FOR MORE INFO "Special For T135 Forumer"...Thanks
New Price list...
Racing Gear Set (Tranny Set) = 11,500
Crankshaft 3.5mm Jack up = 9,000
Faito Infinity Block 60mm kit = 4,000 (Out of Stock)
Turbo Camshaft = 2,800
S4-Evo Camshaft = 2,400
Ignition Coil 7400 = 1,650
Clutch Spring Zero = 700
Engine Valve set Titanium = 2,800
Engine Valve set = 1,800
Racing Clutch Carrier Bushing = 300
Racing Engine Bearing set = 2,000
Clutch Plate Thunder = 2,600
Clutch Plate Swift-Z = 900
Racing Disc Break Pad GOLD (2010) = 1,400
Racing Disc Break Pad PLATINUM (2010) = 2,100
H.I.D Mini Bulb (BLUE or WHITE) = 700 (Out of Stock)
Faito Special Gasket = 650
Faito Plug wire = 800
Plug Cap = 350
21T 4th gear = 1,600
Stock Connecting Rod Set = 2,600
Gear Set 1st,2nd & 4th = 3,600
Kr.r_sniper Location Click the LINKS
http://maps.google.com/maps/ms?msid...&ll=14.630118,121.068523&spn=0.002255,0.00515
CALL OR TEXT 09286144241 PLEASE RESPECT NO LOW BALLERS & BOGUS BUYERS..THANKS T135
NOTE: For Pick up only within Metro Manila,if outside Metro Manila Door to door delivery thru LBC or AP Cargo "Visayas & Mindanao only"...thanks
UP FOR TODAY...
Sonnyjha
paps tanong ko lang dun sa infinity block.. steel bore lng ba sya or Chromebore?? kelan ka kaya magkaka stock nito??
Sonnyjha
ah ok paps..mukang itong 2 parts nato need ko..
and Vixion valve spring sna..
kr.r_sniper
sir ano po pwedeng cam sa stock sniper ko na kabit na lang naka
dbs pipe lang po ako need ko talaga tulong mo.
Wow Sir :D hindi ako expert :D kung gus2 mo tips sa camshaft pde na syo ung stage 1 or stage 2 cams... meron aq S4 Evo d2 stock lift...thanks
