Project 3 Quezon Cityi'l call na lang sir kr.
UPFAITO AVAILABLE PRODUCTS PRICELIST on LIMITED STOCKS@ALL(Regular Price Effective February 2,2012)Racing Gear Set (Tranny Set) = 10,000Crankshaft 3.5mm Jack up = 8,500Faito Infinity Block 60mm kit = 3,800Turbo Camshaft = 2,800S4-Evo Camshaft = 2,200Ignition Coil 7400 = 1,750Clutch Spring Zero = 650Engine Valve set = 1,800Racing Clutch Carrier Bushing = 250Racing Engine Bearing set = 1,800Clutch Plate Thunder (2010) = 2,400Clutch Plate Swift-Z (2010) = 950Racing Disc Break Pad GOLD (2piston) = 1,200Racing Disc Break Pad PLATINUM (2piston) = 2,000Faito Plug wire (HTW) = 75021T 4th gear = 1,800Stock Connecting Rod Set = 2,600Gear Set 1st,2nd & 4th = 3,600
1,500sir meron kapa optional pump bracket? set ba un? pm naman price nid ko
magrerepriced po kmi sa ibang items
hope the prices will be much much lower sir, there are alot of stores selling faito products. and price is now the issue...UPmagrerepriced po kmi sa ibang items
I'll try dochope the prices will be much much lower sir, there are alot of stores selling faito products. and price is now the issue...
because im only a reseller not a wholesaler
ehehehehe...Kr hows the mode of payment or how do i pay you if i'm going to buy your stuff? I'm planning to set my engine to new heights cause i wanna bust the brains of the certified no rules raider riders of davao. here is my number 0906-6213483,kindly txt me as soon as possible since i'm going to buy some stuffs.. thanks a lotI'll try docbecause im only a reseller not a wholesaler
ehehehehe...
FATIO TITANIUM VALVE IS NOW AVAILABLE 19/22 LIMITED STOCKS
the 1st step you need to do bro is to find the TSE Mechanic/Tuner near youKr hows the mode of payment or how do i pay you if i'm going to buy your stuff? I'm planning to set my engine to new heights cause i wanna bust the brains of the certified no rules raider riders of davao. here is my number 0906-6213483,kindly txt me as soon as possible since i'm going to buy some stuffs.. thanks a lot
TSE = Trusted,Skilled & Experienced Mechanic to do the modification,then ask him about the parts you need to get your bike faster than your expectation
no probs with the mech, i'm upgrading my MC on my own for years, got my own tools and other special stuffs (torque wrench and others). i currently installed new kawahara K2 camshaft from traxxas and vixion vavle spring as well. ports and other stuffs on the cylinder head was already complete. what i am interested to is to use 62mm bore and some few modification on the crank shaft if necessary. ignition coils and others regarding with the ignition components, i modified it and i already had a good electrical output using NGK iridium sparks. i'm planning to install vixion kit but i've change my mind, i'll go for 62mm piston as advised by angkol rowan. i still have a yypang long duration stage 3 cam which i'm going to use on the 62mm. Anyway, dont worry bout the mech, i'll do it on my own. just wanna achieve my own mathematics for my bike just like playing a lego hehehe. anyway, txt me your account number, price of the bore as well as the other charges for shipment 0906-6213483. ang kati kati na ng kamay ko, gusto ko na pyesa-pyesahin ang motor kothe 1st step you need to do bro is to find the TSE Mechanic/Tuner near youTSE = Trusted,Skilled & Experienced Mechanic to do the modification,then ask him about the parts you need to get your bike faster than your expectation
Mode of Payment thru Bank bro...then the shipping courier will be LBC "Hari ng Padala"
RIDE SAFE & GODSPEED
wehehehe lets go for mamaw yeahmamaw!
