F/s For Engine Modification Purposes "racing Products"...philippines Market Only
kr.r_sniper
@ALL
Faito Racing Products ON SALE :D from January 23, 2012 up to February 5, 2012 LIMITED OFFER...THANK YOU
FAITO AVAILABLE PRODUCTS PRICELIST on LIMITED STOCKS
Racing Gear Set (Tranny Set) = 8,700
Crankshaft 3.5mm Jack up = 8,000 for H/C & 7,000 for A/C
Faito Infinity Block 60mm kit = 3,200
Turbo Camshaft = 2,500
S4-Evo Camshaft = 2,000
Ignition Coil 7400 = 1,500
Clutch Spring Zero = 600
Engine Valve set = 1,600
Racing Clutch Carrier Bushing = 200
Racing Engine Bearing set = 1,600
Clutch Plate Thunder (2010) = 2,000
Clutch Plate Swift-Z (2010) = 900
Racing Disc Break Pad GOLD (2piston) = 1,000
Racing Disc Break Pad PLATINUM (2piston) = 1,900
Faito Plug wire (HTW) = 500
21T 4th gear = 1,600
Stock Connecting Rod Set = 2,400
Gear Set 1st,2nd & 4th = 3,400
SPECIAL PACKAGE IF YOU BUY CRANKSHAFT + FAITO BORE KIT FREE 60MM SPECIAL GASKET...
ANNIVERSARY SALE ON T135...
