kr.r_sniper
magkano ito paps? yung rubber manifold salpak nalang ba yan?tnx
3,800 yan paps...yup complete yan with rubber manifold...
2,800 po exclude shipping cost...pm paps ung sa tk?...thanks..
salamat bro...sige papa kent ikaw na.. hahaha. up for you![]()
kano po yung uma block? kelangan ba mag palit ng valve pag kina bit yun
txt ko na lang po ung price nya
up for this ..
Uppercut nkakapnlaway tlga mga items ni PAR..![]()
Laki na ng utang ko sa mga toup for this paps...![]()
you can claim your freebies
Free Air sa TIRE
FRONT AND REAR
FAITO AVAILABLE PRODUCTS PRICELIST on LIMITED STOCKS@ALL New Prices after the Promo Period all prices are subject to change without prior notice...thank you T135NOTE: Blue Price is (ON SALE) Red Price (Regular Price Effective February 2,2012)Racing Gear Set (Tranny Set) = 8,700 Original Price 10,000Crankshaft 3.5mm Jack up = 8,000 for H/C & 7,000 for A/C Original Price 8,500Faito Infinity Block 60mm kit = 3,200 Original Price 3,800Turbo Camshaft = 2,500 Original Price 2,800S4-Evo Camshaft = 2,000 Original Price 2,200Ignition Coil 7400 = 1,500 Original Price 1,750Clutch Spring Zero = 600 Original Price 650Engine Valve set = 1,600 Original Price 1,800Racing Clutch Carrier Bushing = 200 Original Price 250Racing Engine Bearing set = 1,600 Original Price 1,800Clutch Plate Thunder (2010) = 2,000 Original Price 2,400Clutch Plate Swift-Z (2010) = 900 Original Price 950Racing Disc Break Pad GOLD (2piston) = 1,000 Original Price 1,200Racing Disc Break Pad PLATINUM (2piston) = 1,900 Original Price2,000Faito Plug wire (HTW) = 500 Original Price 75021T 4th gear = 1,600 Original Price 1,800Stock Connecting Rod Set = 2,400 Original Price 2,600Gear Set 1st,2nd & 4th = 3,400 Original Price 3,600-------------------------------------------------------------------------------------------------------------------------------TKTK Valve Spring = 2,800KAWAHARAK1 = 2,900K2 = 2,900CMScms cams = 2,000cms valve spring (H) = 2,000cms big valves 19/22 = 3,300cms 20t/21t = 2,000cms 124 = 3,800VIXION Partsvixion bore kit = 6,500 w/Head Gasket....6,800 w/Head & Block Gasketvixion top gasket = 450vixion valvespring = 1,900CYLINDER HEADLHK RAIDER VALVE SET = 8,000CMS VALVE SET = 11,000APPI VALVE SET = 11,000HI-SPEED = ?OTHERS6 spring clutch = 2,500ikk clutch gear = 5,500CDIrextor cdi = 5,500brt cdi = Hyper 3,400/Dual 4,000ac to hc clutch kit= 5500UMA Bore kit,Cams & carburetorUMA 62 block = 8.300UMA 28 carb = (24mm-28mm 4,000)(30mm-32mm 4,500)(34mm 4,800)Exhaustnamban = 5,500r9 = 8,500yoshimura = 9,900ahm silver = P5,500ahm gold = P6,500ahm m1 shorty = 8,500ahm m1 longy = 8,500nob1 = 3,500 SMX 3,600yypang = 4,000
wahahahaha...madadagdagan pa yan
from TAIWAN at ITALY
Hindi naman po sa ganunmarami stock na talaga si paps!hehehe...up for this..![]()
