F/s For Engine Modification Purposes "racing Products"...philippines Market Only
kr.r_sniper
FAITO AVAILABLE PRODUCTS PRICELIST on LIMITED STOCKS​
@ALL ​
New Prices after the Promo Period all prices are subject to change without prior notice...thank you T135​
NOTE: Blue Price is (ON SALE) Red Price (Regular Price Effective February 2,2012)​
Racing Gear Set (Tranny Set) = 8,700 Original Price 10,000​
Crankshaft 3.5mm Jack up = 8,000 for H/C & 7,000 for A/C Original Price 8,500​
Faito Infinity Block 60mm kit = 3,200 Original Price 3,800​
Turbo Camshaft = 2,500 Original Price 2,800​
S4-Evo Camshaft = 2,000 Original Price 2,200​
Ignition Coil 7400 = 1,500 Original Price 1,750​
Clutch Spring Zero = 600 Original Price 650​
Engine Valve set = 1,600 Original Price 1,800​
Racing Clutch Carrier Bushing = 200 Original Price 250​
Racing Engine Bearing set = 1,600 Original Price 1,800​
Clutch Plate Thunder (2010) = 2,000 Original Price 2,400​
Clutch Plate Swift-Z (2010) = 900 Original Price 950​
Racing Disc Break Pad GOLD (2piston) = 1,000 Original Price 1,200​
Racing Disc Break Pad PLATINUM (2piston) = 1,900 Original Price2,000​
Faito Plug wire (HTW) = 500 Original Price 750​
21T 4th gear = 1,600 Original Price 1,800​
Stock Connecting Rod Set = 2,400 Original Price 2,600​
Gear Set 1st,2nd & 4th = 3,400 Original Price 3,600​
TK​
TK Valve Spring = 2,800​
KAWAHARA​
K1 = 2,900​
K2 = 2,900​
CMS​
cms cams = 2,000​
cms valve spring (H) = 2,000​
cms big valves 19/22 = 3,300​
cms 20t/21t = 2,000​
cms 124 = 3,800​
VIXION Parts​
vixion bore kit = 6,500 w/Head Gasket....6,800 w/Head & Block Gasket​
vixion top gasket = 450​
vixion valvespring = 1,900​
CYLINDER HEAD​
LHK RAIDER VALVE SET = 8,000​
CMS VALVE SET = 11,000​
APPI VALVE SET = 11,000​
HI-SPEED = ?​
OTHERS​
6 spring clutch = 2,500​
ikk clutch gear = 5,500​
CDI​
rextor cdi = 5,500​
brt cdi = Hyper 3,400/Dual 4,000​
ac to hc clutch kit= 5500​
UMA Bore kit,Cams & carburetor​
UMA 62 block = 8.300​
UMA 28 carb = (24mm-28mm 4,000)(30mm-32mm 4,500)(34mm 4,800)​
Exhaust​
namban = 5,500​
r9 = 8,500​
yoshimura = 9,900​
ahm silver = P5,500​
ahm gold = P6,500​
ahm m1 shorty = 8,500​
ahm m1 longy = 8,500​
nob1 = 3,500 SMX 3,600​
yypang = 4,000​
UP FOR TODAY
kr.r_sniper
salamat po... hihingi pa po aku nang suggestions kung anu dapat e lagay ko s stock n engine ko para mka pili po aku ng items nyu,,,,salamat po ulit god bless
boss ask mo na lang ung mga masters tlga :D for me basic mods...cams,valve spring,clutch spring,cdi,exhaust system...kung gus2 mo pa ng mas malupit big valve,bore up,stroker pin :D
dennmay16
mga magkanu po lahat kung basic mods lng po e apply ko at charge sa shipment po sa cebu po aku...salamata po.
kr.r_sniper
@ALL
BRT CDI Power Max for UB & SCOOT is now AVAILABLE (Hyper Band & Dual Band) :D
We Accept Bulk orders minimum of 5pcs for BIG Discount + Free Shipping any part of the country...all CDI are LATEST realease especially for LC135/Sniper/SniperMX January 25,2011...
