FS: 26mm Genuine Mikuni Carburetor (Plug & Play)
CLYDE
musta nan performance niya sir @CLYDE ??? compare sa 28mm at stock? sa responde at top end?
Based on my experience Keihin PE28 provides better response at very high RPM range (full throttle mode) , vm26 gives better low end torque, responsive midrange and respectable topspeed (very good for touring purposes). I think vm26 is the best all around carb between the three (stock carb for those who still want to use tps, PE28 for those who love racing or high rev driving, vm26 for fuel economy, touring and occasional road racing:D)
CLYDE
I have two VM26 dati, recently sold the other one in the forum to buy 28mm so i would know the difference in performance. Now im back to using vm26 again for long distance ride reasons (Fuel economy with respectable topspeed). Ang issue lang sa vm26 eh you have to put a tube spacer on the top of the carb kc sobra haba stock throttle cable kapag nagpalit ka ng carb na to with smx manifold, dmo makukuha sa adjust khit sagad pa kung d mo lalagyan ng spacer. sabi nung iba vega cable daw ang sakto. Heres the pic of what i did
Uploaded with ImageShack.us
DeViLsToRm
I have two VM26 dati, recently sold the other one in the forum to buy 28mm so i would know the difference in performance. Now im back to using vm26 again for long distance ride reasons (Fuel economy with respectable topspeed). Ang issue lang sa vm26 eh you have to put a tube spacer on the top of the carb kc prang sobra haba stock throttle cable kapag nagpalit ka ng carb na to with smx manifold, dmo makukuha iadjust khit sagad kung d mo lalagyan ng spacer. sabi nung iba vega cable daw ang sakto. Heres the pic of what i did
sir clyde/admin traxx,
heres my spark plug reading using vm26, mainjet 150, needle jet in midde position with stock air filter.vixion kit, kawahara cam.
im wondering bat ganito?diba lean ito masyado?any suggestion?
CLYDE
Try to adjust your a/f mixture because different bike requires different settings, i don't use air filter 2 turns out works well on my bike #20pj #150mj
Ginger
sir traxx yung setting b ng carb n ibbenta mo according sa karga ng motor ng bibili or bahala kna po???
sir traxx when will your stock be available? wala ba to TPS?
no tps, if you want tps follow the TPS POORMANS MODS
the carb i will give you will be for the ff setup: stock or vixion bore kit.
any other mods, you will rejet it yourself. basically plus or minus jets lang.
all jetsize are readily available sakin.
@CLYDE
follow the plugchop procedure.
search mo lang sa internet ano ang plugchop procedure.
mac kevin
can this be fitted to sniper classic or need to change manifold?
P3900(carb)
P160 (shipping)
P?____ (manifold 2011)
=P____________
