Based on my experience Keihin PE28 provides better response at very high RPM range (full throttle mode) , vm26 gives better low end torque, responsive midrange and respectable topspeed (very good for touring purposes). I think vm26 is the best all around carb between the three (stock carb for those who still want to use tps, PE28 for those who love racing or high rev driving, vm26 for fuel economy, touring and occasional road racingmusta nan performance niya sir @CLYDE ??? compare sa 28mm at stock? sa responde at top end?
I have two VM26 dati, recently sold the other one in the forum to buy 28mm so i would know the difference in performance. Now im back to using vm26 again for long distance ride reasons (Fuel economy with respectable topspeed). Ang issue lang sa vm26 eh you have to put a tube spacer on the top of the carb kc prang sobra haba stock throttle cable kapag nagpalit ka ng carb na to with smx manifold, dmo makukuha iadjust khit sagad kung d mo lalagyan ng spacer. sabi nung iba vega cable daw ang sakto. Heres the pic of what i did
Uploaded with ImageShack.us
if you are into racing, go for bigger carbs 28mm,30mm,33mm. Bigger carbs gives more power and more fuel cost.musta nan performance niya sir @CLYDE ??? compare sa 28mm at stock? sa responde at top end?
no tps, if you want tps follow the TPS POORMANS MODSsir traxx when will your stock be available? wala ba to TPS?
the carb i will give you will be for the ff setup: stock or vixion bore kit.sir traxx yung setting b ng carb n ibbenta mo according sa karga ng motor ng bibili or bahala kna po???
for yamaha Sniper Classicwhat is the stock main jet and pilot jet of mikuni carb? TIA
