72 /22 = 3.272Sir traxx nu po ratio nyan sa mx?
Sir meron p stock sa SMX?pa order sna.ska pilot jet png stock carb SMX. #22.5 or higher. My No. 09274440028For Sale:
Brand New IKK Primary Drive Clutch Gear (set)
72t clutch gear , 22t driven gear
(works in 2010 and older models of Yamaha Sniper T135 HC)
Price: P5500
Sir du u still have stocks for sniper mx?kindly pm or sms.i want to order.tnx.72 /22 = 3.272
2pcs left for sniper mx clutch gear
pm me for discountayun meron na rin palang pang SMX na ganito.. hinde ba tama ung ratio na nkalagay sa sniper mx owners manual? hinde ba 73/24 na ang smx primary drive gear ratio? magkano po sir ung pang SMX same price din ba? thanks!
sir job the ikk primary gear ratio for the old 4 speed is the same as for the 5 speed mx??? the stock primary gear for the 4 speed is 2.875 while for the 5 speed is 3.042
same doc, it will make mx 5th gear more usable new ratio 3.272sir job the ikk primary gear ratio for the old 4 speed is the same as for the 5 speed mx??? the stock primary gear for the 4 speed is 2.875 while for the 5 speed is 3.042
ok. i was looking at the parts manual of the sniper mx. i thought the orientation of the clutch gear and primary drive gear was different with the MX. there is a drive gear at the back of the clutch gear for the kick starter i think.same doc, it will make mx 5th gear more usable new ratio 3.272
there is a drive gear at the back of the mx clutch gear. if similar to the yamaha DT that is fixed.
Sir job have u try to install this gear to SMX? Is it true that u have to remove the small gear behind it? If so then ur kick started would be unusable? Any advice on this?same doc, it will make mx 5th gear more usable new ratio 3.272
for the MX i think you should consider using the primary gear from the yamaha zerow 225. it has a primary gear of 22/73. it has also a gear starter gear at the back of the clutch gear.Sir job have u try test to install this gear to SMX? Is it true that u have to remove the small gear behind it? If so then ur kick started would be unusable? Any advice on this?
Thanks doc for the info..i was planning to purchase this gear before but i do need the kick starter too...now the problem is where cud i get the stock gear from zero 225.doc does it fits exactly for Smx?for the MX i think you should consider using the primary gear from the yamaha zerow 225. it has a primary gear of 22/73. it has also a gear starter gear at the back of the clutch gear.
