Definition of Gearing Ratios
By Peggy Deland, eHow Contributor
In the automotive industry, gear ratio refers to the difference between the input and output speed of a differential or trans-axle. The purpose of the gear ratio is to give the best combination of performance and economy for a given engine size and vehicle weight. Some gear ratios are designed to operate outside of this condition, such as those used by hot rods in drag racing.
Function
· In the simplest terms, a gear ratio is the difference in size between two gears that have the same tooth spacing. One common ratio is the 4.10 gear ratio used in heavy-duty pickup trucks and drag-racing cars. This ratio is considered "low-geared"; for every revolution the larger gear (attached to the axles and wheels) makes, the small gear (attached to the drive shaft) makes 4.10 turns. This gear reduction gives increased power at the expense of top speed and fuel economy. An example of a "high-geared" ratio would be 2.62, where the large gear that drives the wheels turns once every time the drive shaft gear turns 2.62 times.
Effects
· The effect of the gear ratio is to convert rotational energy--in this case coming from the drive shaft--to a desired level of energy at the wheels. The gear ratio does not increase horsepower; it merely changes how it is used. A lower ratio offers greater power while sacrificing top speed, whereas a higher ratio offers greater top speed with less power. Gear ratios also affect the vehicle's fuel economy. A higher gear ratio offers greater fuel economy on the highway, and a lower ratio will be less efficient. This is because the higher a gear ratio is, the fewer revolutions the engine has to make to achieve a desired speed. Since one of the things that affect fuel economy is engine RPM, fewer revolutions per minute use
lessfuel.
