Fs: Primary Driven Gear And Ikk Drive Clutch Gear Assembly Kit
docgabby
Im lookin forward for sir KRB discovery..iv been waiting for this mods to finally fit in my mx..my first option with the ikk gear was close..if only it has gear for the kick starter then probably its been awhile since i install it in my bike..now my hope is with sir KRB...hopefully hed be kind enough to share with us..
krb is an enthusiast just like you and me. his desire to try out new ideas is highly commended. but his limitation by parts availability, trial and error, costs is also very unfair to him to us waiting for the results. "hirap nya, ginhawa natin" he was hesitant to share his preliminary results because of the blood and sweat he put to the experimentation. in fact when we last texted he was hoping ikk or any maker would come up with a primary gear saving him all the effort. just plug and play. but some us are very impatient to wait. don you know at the moment krb is looking at about 4-5 primary gear ratios of differene models just to try out....he may or may not reveal his total know how but for sure he will give us all an idea how to go about it. in fact he has even made me look at the available models i can get my hands on and tell him does it or does not fit..the only problem is not all would want their MX to be experimented om.
Samboy Del Rosario
sir krb. anong crankshaft nkaka bit dyan? nka pin ba or ung faito crank? nsa 4mm ata ung aluminum gasket?
yan din ba bro ung nka drive gear? ang liet ng sprocket sa likod parang nsa 34 lng hehehe. ok pa kaya yan sa long rides?
LUFET! GALING! :thumbsup::thumbsup::thumbsup:
kimredbull
pang touring po tlga yan.4 da mintym pwd ma drag..uu yan ung nka drive gear,den ung crankshaft nyan nka jack up ng 4mm..gawa q lng yan
docgabby
Definition of Gearing Ratios
By Peggy Deland, eHow Contributor
In the automotive industry, gear ratio refers to the difference between the input and output speed of a differential or trans-axle. The purpose of the gear ratio is to give the best combination of performance and economy for a given engine size and vehicle weight. Some gear ratios are designed to operate outside of this condition, such as those used by hot rods in drag racing.
Function
· In the simplest terms, a gear ratio is the difference in size between two gears that have the same tooth spacing. One common ratio is the 4.10 gear ratio used in heavy-duty pickup trucks and drag-racing cars. This ratio is considered "low-geared"; for every revolution the larger gear (attached to the axles and wheels) makes, the small gear (attached to the drive shaft) makes 4.10 turns. This gear reduction gives increased power at the expense of top speed and fuel economy. An example of a "high-geared" ratio would be 2.62, where the large gear that drives the wheels turns once every time the drive shaft gear turns 2.62 times.
Effects
· The effect of the gear ratio is to convert rotational energy--in this case coming from the drive shaft--to a desired level of energy at the wheels. The gear ratio does not increase horsepower; it merely changes how it is used. A lower ratio offers greater power while sacrificing top speed, whereas a higher ratio offers greater top speed with less power. Gear ratios also affect the vehicle's fuel economy. A higher gear ratio offers greater fuel economy on the highway, and a lower ratio will be less efficient. This is because the higher a gear ratio is, the fewer revolutions the engine has to make to achieve a desired speed. Since one of the things that affect fuel economy is engine RPM, fewer revolutions per minute use lessfuel.
docgabby
with the ikk primary gear ratio you increase pick up speed but you loose top speed and you will loose fuel economy. the primary gear ratio in motorcycles is like the differential ratios in automobiles (automobiles have differential ratio-its their primary gear and final drive ratio in one and transmission ratio, motorcycles have three- primary gear ratio, transmission ratio and final gear ratio.). with motorcycles we can alter the primary gear ratio like the use of ikk, alter the transmission ratio as with gearbox set, alter the final drive ratio as in engine and rear sprockets............:coffee:
