dude_pare01
a friend of mine is interested on the rextor mio CDI...sms me papa traxx
Nice Item you have sir! go go go sir traxxas and very good sellertraxxas-modifier said:Hi guys,
below is my personal experience about rextor adjustable cdi for Yamaha T135.
Rextor Adjustable CDI Designed for T135 with TPS FULL Support
(NO REV LIMITER) Specifically Tuned for T135
Im selling a rextor adjustable cdi especially designed for Yamaha T135
with FULL THROTTLE POSITION SENSOR (TPS) support and Thermosensor FAN support.
Rextor Adjustable CDI for Yamaha T135 have builtin 30 folders that contains Ignition Timing Mapping Graphs.
This means for every 0.04volts of change in TPS sensor, a specific folder
with graphs is used for better performance. The graphs were dyno tested
to provide better performance on all powerband.
Adjustable CDI for T135 uses
Motorola" Microprocessor featuring Motorola"
MC908QY4 Technology
This adjustable cdi for Yamaha T135 also provides additional features
- Advanced the ignition timing upto 4 degrees.
Advance the ignition timing by turning the dial counter clockwise
- Retard the ignition timing upto 4 degrees.
Retard your ignition timing by turning the dial clockwise.
- LED red light indicator for ignition timing
You can use this red led light to know if you want to use stock ignition timing or advance or retard setting.
- LED green light indicator for TPS with TPS TUNER.
You will know if your TPS is functioning properly thru this led greenlight.
You can also use this led green light to properly tune/adjust your TPS in correct angle. The correct angle for your TPS is important so that you will
have the best performance.
- Radiator FAN function checker.
the rextor adjustable cdi for yamaha t135 will check if your fan is working properly. Every ignition on, The radiator fan will turn on for 4 seconds. No more worrying to know if your fan is working or not.
- Thermosensor Overheat Temperature Support
The rextor adjustable cdi for yamaha t135 supports overheat temperature sensor. Your temperature will light (panel meter) if your engine overheat.
so you dont need to worry about your engine.
-Dyno Tested and No revolution limiter
this means you will now experience better speed and acceleration due to no rev limiter. And all ignition graphs used
were tested using dyno meter.
i personally use this Rextor adjustable CDI in my bike and im very satisfied due to FULL support of TPS and FAN sensor with additional features that cannot be find in stock cdi. Plus added top speed!
OTHER REXTOR CDI:
-programmable cdi for carbs that dont use TPS. Contact me for specific pricing
FOR ORDERS:
Contact me,
Shipment will arrive anytime soon.
discount will be given for advanced payment.
PRICE:
Philippines: P4500 (shipping is free)
Asian countries: USD$100 (usd$20 shipping fee)
Other countries: please PM for shipping rates
PAYMENT:
Philippines: payment can be send via bank deposit, globe gcash
Other countries: paypal or western union
INSTRUCTION MANUAL:
Manual on the Rextor CDI can be downloaded here - DOWNLOAD REXTOR CDI MANUAL
Heres an intro video
[flash width=425 height=355]http://www.youtube.com/v/3w8n8DXD3VE&rel=1[/flash]
How to Adjust the IGNITION TIMING
[flash width=425 height=355]http://www.youtube.com/v/cNLqsUVEgmI&rel=1[/flash]
thanks for the info sir. pm sent.traxxas-modifier said:@depedal
yes bro will fit perfectly in the T135 cdi casing...
see pics
