HEHE...MAMAHAGI NMN...inubos na nmin kaya antay mga pogi
up
...ANY FEEDBACKS FOR THE PERFORMANCE?HEHE...MAMAHAGI NMN......ANY FEEDBACKS FOR THE PERFORMANCE?
ito ba yung UMA hi flow oil pump paps?sir traxx available na b oil pump?
need to change my oil pump
d na kaya calibrate may tama na din ang loob ng pump housing
yan ung stockito ba yung UMA hi flow oil pump paps?
Up Up Up,,,Kindly reserve me 1pc.....NOW READILY AVAILABLE UMA RACING OIL PUMP.
P2000 each
Thank you also Boss Admin,,,for giving me discount,,,until next transaction.....thanks Batang Kadlit![]()
I'm using the oil pump now. My mechanics done some small modifications to the Oil drain of the engine, to enhance the performance much more. This UMA PUMP have different gear compare to stock. Which aloud more oil to go in. Furthermore the hole of the pump compare to stock is bigger by 2mm. Everybody must have thought why not i drill the hole bigger? Yar you can drill the hole but still the stock gear is different from UMA. UMA gear aloud more oil to go in. Why you want change to this filter?
My Personal Feedback
1. More oil can circulate in the engine so this will reduce heat on Oil
2. Cooler oil that circulate in the engine will contribute to increasing horsepower.
3. Higher Durability and Efficiency.
4. Is a must for big bore kits. Even brand like Kitaco and Takegawa include this oil pump for they bigger cc big bore kits.
5. Value for money.
